Old 03-13-2018, 03:58 PM
PatrickN PatrickN is offline
Default New Builder and Trailing Edge Question
Hello All,
I'm a new RV-14 builder - yes, no 'A' and little wheel in back . I am working on the rudder and have a question for the community. Sorry if this was answered, but I couldn't find any information from searching.
On page 07-09 - steps 1 and 2, the instructions say to use adhesive to bond the trailing edge. However, on page 07-10 - step 2, the instructions say "The trailing edge will have to peeled slightly ...". I was planning to use the 3M F9460PC VHB tape as specified in section 5. Looks like the 3M tape is a permanent bond, so why would we bond the trailing edge, then attempt to peel it apart again? Won't peeling the edge apart potentially damage the skins? Has anyone used the 3M tape for the trailing edge? Looks like Van's used to recommend using fuel tank sealant.
Thanks!
Old 03-13-2018, 04:33 PM
This is an error that has been noted previously but I guess not yet corrected.
The intent is that you bond the T.E. to the right skin, and then add the VHB tape to the left skin but do not pull the backing off.
Then follow the steps regarding rolling back the skin to rivet the stiffeners.
Once finished, you carefully pull the backing from the second piece of tape and allow the left skin to contact the tape.
Scott McDaniels
Hubbard, Oregon
Old 03-13-2018, 04:38 PM
Thanks Scott! That makes sense.
RV-14 #140469
Empennage Kit Complete - mostly
Working on Fuselage Kit.
Old 03-13-2018, 04:49 PM
Default Welcome to VAF
Patrick, welcome aboard the good ship VAF
Old 03-14-2018, 06:41 AM
tyconnell tyconnell is offline
I had very good results using the VHB tape on my -9 rudder trailing edge. I bought a ~ 4' piece of aluminum angle from Aviation Depot. This angle was mounted on the front of my work bench, flush with the bench top. Then drill / cleco the skins / wedge to it. Tape goes on, one side at a time, using the "peel back" method Scott describes.
I'm not sure what the -14 manual has in it, but I believe the above is a the recommended / common approach to these types of TEs.
Take your time with it.
Ty Connell
Atlanta, GA
EAA Chapter 690
VAF dues paid monthly
ty.connell@gmail.com
N997TL reserved
RV-9(A?) empennage in progress
Old 03-14-2018, 10:12 AM
KeithB KeithB is offline
If you can get away with it, a granite counter top in the kitchen makes a great flat surface for making very straight trailing edges. Home politics is the builder’s responsibility :-)
Keith Brown
RV-14A Builder - kit #136, XP-400 Aero Sport Power
N314KC - First flight Mar 8, 2017, >375 hrs
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 12/2018
Old 03-14-2018, 10:51 AM
Thanks all! I am hoping I'll get to the point of finishing the TE this weekend.
RV-14 #140469
Old 03-15-2018, 06:50 AM
ShortSnorter ShortSnorter is offline
Just don't use proseal
Ryan
RV-14 In-Progress
Build Site
Old 03-15-2018, 10:38 AM
Carl Froehlich's Avatar
I used two pieces of 2”x2”x1/8” steel angle, the angle surface covered with a piece of packing tape. I also used a 3M two part epoxy instead of pro-seal, but pro seal is fine as well.
One angle hanging over the table edge, the control surface edge on the table and wood shims under the rest of it to keep it at the same height of the trailing edge. Epoxy and a cleko in every hole, then the second piece of angle on top of the control surface just on the other side of the clekoes.
This worked well for the RV-10 and RV-14 control surface trailing edges. They all came out straight as an arrow.
Old 03-15-2018, 02:57 PM
StressedOut StressedOut is offline
I'm at the exact same step as you are Patrick. I got a 5 ft. long 1 x 2 x 0.10 steel rectangular tube to hold the edge straight, but I'm a little unsure as to exactly how to use it. This weekend will be spent reviewing Section 5 in detail before I proceed. I'm a little nervous about messing this up.
Good luck on your trailing edge.
Art Jackson
RV-14A Kit#140433, N393AJ Reserved
Completed: Vertical Stab/Horizontal Stab
Scrapped: Rudder
Working on: Empennage (Elevator)
Construction log - mykitlog.com/ajackson
Dues paid on 10 October 2018
Member of EAA Chapter 92 (KCNO)
Pet peeve: "Lose" is the opposite of "find". "Loose" means "not tight".
