Old 03-08-2018, 06:12 AM
tomkk's Avatar
tomkk tomkk is offline
I can't see the pics ...
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845; first flight 06/10/2015
RV-12 N918EN ELSA #120995 Eagles Nest Project
SPA Panther N26TK in progress
Old 03-08-2018, 06:57 AM
sprucemoose's Avatar
sprucemoose sprucemoose is offline
Originally Posted by Jpm757 View Post
I had a tip up on my 6, and I cut a notch in the forward face of the roll bar that allowed the aft portion of the latch to rotate "into" and lock the canopy open several inches.
I understand how this would work but I am curious why you did it? What would this accomplish that the stock set-up would not? It would seem to restrict the amount of airflow coming in, so what is the upside?
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
Old 03-08-2018, 07:59 AM
BillL BillL is offline
I read that as "slot" rather than a "notch". It might address the possibility of a tailwind/gust lifting the canopy when stationary and fiddling in the cockpit. It would seem the latch could only be in a locked position when activated from the inside.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Old 03-08-2018, 10:03 AM
6ato14a 6ato14a is offline
Default Try again for pictures
http://tgi.com/sites/default/files/s...?itok=_xx67Q6Z
http://tgi.com/sites/default/files/s...?itok=U9WrwdDE
I hope these work. I'm a bit of a Luddite.
Old 03-08-2018, 11:06 AM
Sam Buchanan's Avatar
been here awhile
Originally Posted by 6ato14a View Post
That is pretty clever, but in the nearly twenty years of taxiing my RV-6 tip-up I've never felt the need for that modification. The propwash keeps the canopy down against the roll bar when in the taxi position.
The RV-12 canopy video referenced in a previous post isn't reason for me to worry about a mishap. If a tailwind is really severe during taxi, it is a simple matter to just close the canopy. The RV-12 has a different canopy design from the other tip-up RVs.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
