Old 03-06-2018, 06:47 PM
tomkk's Avatar
tomkk tomkk is offline
Default Help with a measurement
Our Eagles Nest project is starting to lay in the fuselage wiring, the WH-00045 and WH-00046. The red bands have slipped, however, so we can't tell where to initially position the harnesses.
Can someone who has the harnesses handy measure the distance from the connector to the red band for both of the harnesses?
I thought I remembered seeing a similar post 2 or 3 years ago but can't seem to find it.
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845; first flight 06/10/2015
RV-12 N918EN ELSA #120995 Eagles Nest Project; ready for engine & avionics
Old 03-06-2018, 07:05 PM
Special Delivery's Avatar
Special Delivery Special Delivery is offline
Tom,
There are actually two bands on the legacy fuse harness, an upper and lower. If you don't get a response here, I can get the upper measurment from Montgomery on Thurs. Keep up the great work!
R. E. "Ernie" Butcher
Friends of the RV-1/Eagle's Nest Projects
"Mentors build the student...
Students build the airplane." -Glen Salmon
Dedicated to the historical preservation of the RV-1 Aircraft
and organized for the purposes of promoting, supporting,
fostering, and engaging in aviation and aerospace education.
www.RV-1.org
www.EaglesNestProjects.org
Old 03-07-2018, 05:59 AM
tomkk's Avatar
Thanks, that would be great if someone doesn't put it up first.
Tom
Port Orange, Fl
Old 03-07-2018, 07:42 AM
John-G John-G is offline
Tom,
On the older wire harness the bands are located approximately 23" and 62" from the end of the connector. That should get you in the ballpark. I had the same problem as you in that my red bands moved as well. I used a sharpie and painted marks on the wires.
http://www.dogaviation.com/2014/04/i...e-harness.html
Happy building,
_________________
John
www.dogaviation.com
Now Flying!!
Dues paid until September 2018
Old 03-07-2018, 08:24 AM
tomkk's Avatar
Thanks, John. I knew I'd seen those measurements somewhere, it might have been your site rather than the forum. Thanks again.
Tom
Port Orange, Fl
Old 03-07-2018, 04:39 PM
Mich48041 Mich48041 is offline
The wire part numbers include the length (unless they changed them recently).
Edit: Oops, I misinterpreted the question.
Joe Gores
RV-12 Flying
