Old 03-03-2018, 01:55 PM
Mycool Mycool is offline
Default Engine air intake
Working on air intake, does anyone know minimum air intake hole size? I'm guessing it can't be smaller than the air intake in the carb itself. Of course the bigger you go the more you get. Is there a chart on size vs performance?
US ARMY VETERAN
MEI-I
A&P
RV Transitional trainer
RV9A - So close to flying
RV3 a -
Wheeler Express - Sold
Old 03-03-2018, 03:47 PM
longline longline is offline
Default Air intake size
If you are referring to induction air, I just finished researching that. For the O/IO 360 engine, at 2500 RPM and 180 MPH it seems that 2.2 inches in diameter is the minimum number... rounded up to 3 inches would give about I inch ram increase without inducing much drag. Larger is not necessarily better here, as the drag would increase with a larger duct.
If you are talking about engine cooling air I would refer you to the DanH "shrinking exit" for exhaustive discussion.
Others, more knowledge than I, might chime in here.
Old 03-03-2018, 04:10 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
This depends quite a bit on what your duct material is. If you duct with SCAT hose, plan to go up in diameter a fair amount, depending on run length. SCAT has very high losses, especially a few feet of it.
If smooth inner wall, you don't need anything bigger than the throttle plate area and maybe not even that big as the venturi or servo throat is usually quite a bit smaller in area than that.
Turbo Subaru EJ22, Marcotte M-300, IVO, RV6A C-GVZX flying from CYBW since 2003- 420 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi.htm
Old 03-04-2018, 10:24 AM
Default Ross
is correct. I had settled on SKEET tube, and did not think to mention the loss that would occur with something not smooth walled. Excellent catch!
My induction intake is designed to do away with the typical folded baffle material seal and reduce losses to the lower cowl volume.
Old 03-04-2018, 12:47 PM
Default Question
“Longline” thank you for clarification, I am talking about induction air. Where did you get that “2.2 inch diameter” from? My engine is a O-320.
US ARMY VETERAN
MEI-I
A&P
RV3 a -
Old 03-04-2018, 06:25 PM
Marc Bourget Marc Bourget is offline
I think you can go larger than 2.2" if you design the intake opening correctly, Same as for cooling intake.
With engine intake, a superior installation would have a smooth intake duct with diminishing cross section down to the correct size.
