Old 02-13-2018, 11:01 AM
Karetaker Karetaker is offline
Default Quality Issue With Left RV7 Wing Tip
Hello crew. I am curious if another RV7 builder has noticed a quality issue with the left wing tip trailing edge? I received my wing kit a couple weeks ago and my left tip trailing edge is not fully molded. The shape is there, but it does not seemed to be fully developed and has various gouges and voids. I am just curious if anyone else has seen this issue?
(I don't have my pictures stored online to upload here...my apologies.)
Old 02-13-2018, 01:13 PM
bruceh's Avatar
bruceh bruceh is offline
Fiberglass is infinitely fixable/fillable. Just wait until you see the cowling!
Bruce Hill
RV-9A N5771H flown over 600 hours!
http://www.overthehills.com/RV-9A-Project
APRS Tracking for KJ6YRP and New Flying Blog
2018 VAF donator
EAA Tech Counselor
Old 02-13-2018, 01:27 PM
9GT's Avatar
9GT 9GT is offline
Fiberglass parts are easily fixed and it is not at all uncommon for the fiberglass parts to need some fixing before final fitting and painting. I know that on my RV-10 wingtips, I had to split the trailing edge on both tips in order to get it lined up straight with the ailerons and flaps. One side was also about 1/2" too long on the trailing edge. You may find some pillowing or dips in the skins of the tips after you get them fitted so fix those also. You don't want them acting as a trim tab.
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2018
Old 02-13-2018, 01:54 PM
Lemmingman's Avatar
Lemmingman Lemmingman is offline
I have the older wingtips, white. I think the new ones are gray. I found surprisingly few issues with them. The trailing edge does need some work, more than the leading edge.
Gil Brice
McKinney, TX EAA-1246
RV7 - Working on fuse, fuel, brakes etc...
rvblog.thebrices.com
Old 02-13-2018, 04:51 PM
Champ's Avatar
Champ Champ is offline
Like others I slit the trailing edges, lined them up and reglassed.
Dennis Enns
Kingsville, ON
Bellanca Champ 7ACA since 1986, restored 1990.
RV-8 IO375, Hartzell CS, dual PMags.
Dues paid thru Dec 22, 2018
Old 02-14-2018, 07:34 AM
OK, just checking. All other fiberglass tips received, (empennage/wings) were beautiful out of the box, so when I saw the left wing tip I was a little struck.
Thank you.
Old 02-24-2018, 10:50 AM
Turbo69bird Turbo69bird is offline
The guy who owned my 6 had installed a new wingtip and it was way off from the aileron it needed to be split too. It freaked me out a bit to have to do that being new to RVs but apparently itís pretty common and the builder had had to do it on the original when it was built.
New owners A&P when replacing the tip had no idea and just installed it out of the box. It amazes me the things I see A&Ps miss on RVs that a good RV builder will pick up in seconds.
Proud owner of 925RV
Special Thanks to Fred Stucklen
While I'm not a builder if I happen to give advice , I will not be responsible for damage to equipment, your ego, parts, world wide power outages, spontaneously generated black holes, planetary disruptions, or personal injury that may result from the use of this advice.
