Just a little help please? I am currently running a Grand Rapids Dual HS system with the 429 ARNC options with a GNS430W and GTX330. Both the GRT system and the GNS430W display TIS-B traffic from the existing GTX330.
So, I recently upgraded my GTX330 to the ES (extended squitter) for ADSB-out. It came back with different settings and a few additional config pages having to do with the ADSB outputs. I was initially told no additional wiring would be required but I understand now that I will have to pull the connector on the 430W unit and add a RS232 output to feed the ES option on the GTX330ES.... that's a real pain in my airplane as the 430W is at the top of the radio stack.
I'll do what I have to do but I can't seem to locate a install/config manual for the newer or upgraded GTX330ES that shows the new config pages and what the options really do and where the pin in should go. I also understand that the GNS430W must be updated to the latest software as well but not positive what version that is.
Does anyone have a link to a newer manual showing the install/config options for the GTX330ES and any thoughts, comments, experience on the need to add the GNS430W RS232 output would be appreciated ??
Looked for manual links in other posts on "squitters" but didn't find any.
Thanks Bill S
Thanks Bill S
