Old 06-20-2011, 12:03 AM
DanWright DanWright is offline
Originally Posted by Tony_T View Post
Here is a link to the level I use...
Tony
Design drawings for your enhanced unit?
Dan Wright
Building RV-12 #511 in the Mojave desert (1976W reserved)
Old 06-20-2011, 08:42 PM
Ausflyer Ausflyer is offline
Default Thanks for the advice
Dicks advice that thr resolution of these levels is 0.2 degrees does not surprise me. Perhaps like digital watches, there are only a couple of manufacturers of the basic chip, and all the watches are just variations on cases, displays, buttons etc.
Thanks for all the suggestions for a useable levels. I have ordered the one Tony chose. Sears' offering looks good too, but they wont send it overseas.
Thanks again for the great response
Rod
Old 06-27-2011, 01:33 PM
dick seiders dick seiders is offline
Finally made my digital level brkt (ala Tony T. pics) yesterday. Checked pitch on blades today and found .65 degrees difference. (67.70 and 68.35) So the Warp bubble protractor didn't do too badly. However, Sensinich says it wants diff. to be no more than .250 so reset using the digital. After 3 tries moving one blade only I managed to get 67.80 degrees to almost match the other at 67.70. It's tricky as I learned that after setting with bolts somewhat loosened the reading increases slightly when bolts are torqued. Will fly tomorrow and see if I can detect any difference. I must agree the digital is better as far as setting it up.
Thanks.
Dick Seiders
Old 06-28-2011, 11:43 AM
After short test flight today I re checked the prop and readings are still w/i .1 degree. Very cool.
Dick Seiders 120093
Old 06-28-2011, 12:07 PM
MartySantic's Avatar
MartySantic MartySantic is offline
I built the John Bender fixture for use with a digital level. Modified it slightly by adding a angle on each side of the level. Rubber bands hold the level snugly in place. One caution, before riveting the 2nd end piece in place, put the fixture on the prop blade the ensure it fits correctly due to blade twist.
http://www.vansairforce.com/communit...stment+fixture
Marty Santic ----- W9EAA
RV-12 N128MS ----- Now Flying
My RV-12 Build Log - http://www.martysrv12.blogspot.com/
Davenport, IA
Old 07-09-2011, 02:56 PM
Walt's Avatar
Walt Walt is online now
Originally Posted by Walt View Post
I first checked Pete's RV12 with the weights installed from the previous balance and found it over the limit at approx 0.260 IPS. We removed the previous weights and started over, results below. Went from 0.460 to 0.039 IPS (the red circle in the polar plot represents the upper limit of 0.2 IPS).
Above is Pete's RV12
Below is John's RV12
Another RV12 balance for reference, initial vibration of .425 IPS, after balance .018
Took me 4 runs on John's... (note upper limit is red circle)
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Old 09-21-2017, 12:00 PM
AirHound AirHound is offline
Walt I'm Doug in IL. I am waiting for hub replacement IAW theSeninich B revision exchange program. I bought my 12 built/used and it had a dynamic bal job 3 years ago. What to do now with new hub? Take off balance bolt nut and washer and hope for the best or just install new hub? And wish for the best? I don't have dynamic balance capability near by?
Doug
Old 09-22-2017, 08:17 PM
E. D. Eliot E. D. Eliot is offline
Default Request - please
Request that someone could post the drawings for the fixture again. The old drawing posts have been wiped out by? Thanks in advance.
Building finally
