Old 02-17-2009, 04:39 PM
bearcatkm bearcatkm is offline
Default RV=10 seats
RV-10 front seat cover pattern out there?
Old 02-17-2009, 04:47 PM
Hey Kevin, in case no one else has said it, Welcome to VAF!!!
IIRC, the patterns are supposed to be included with the foam.
You could always check with Vans direct.
Old 02-17-2009, 06:17 PM
PJSeipel PJSeipel is offline
I asked Van's about this a few years ago since patterns were mentioned in the plans:
Oregon Aero don't appear to put any documentation in the seat box.
We called them to find out if they do have anything, but haven't
received an answer, so I assume that they don't have seat cover
patterns etc. Apparently we were optimistic when we assumed there
would be some documentation in with the seats
Vans
Old 02-17-2009, 09:52 PM
Thank you for the welcome.
I called van's today and they do not offer front set covers or patterns for the RV-10 they let me know that it would be an infringement on the set manufacture
Hounds forever.... ..... ... ....
Old 10-11-2017, 05:13 PM
steve murray's Avatar
steve murray steve murray is offline
Default Renewing old thread - RV10 seat cushion patterns?
Anybody have some seat cushion patterns they are able to share? My sister is a very talented seamstress but her love for me has it's limits.......said she will only sew my RV10 seat covers with a pattern
Steve
Steve
RV8 Flying since 2007
RV10 in construction (Fuselage)
Old 10-11-2017, 08:11 PM
Brandi's Avatar
Brandi Brandi is offline
Steve
Haha! I don't blame her! =)
I made mine from scratch. If you like the design, I can snail mail my homemade "patterns" to her. I don't mind explaining my process either.
Photo of my front seats
Brandi Unrein
RV-10 - 650+ hrs (map)
First flight 6/16/12
http://n42bu.com/
Old 10-12-2017, 06:45 AM
Hi Brandi. I will definitely take you up on that offer. Once I have the foam cushions in hand, I will PM you to work the details and have you talk to her. (This will probably be 6 months or so from now.) Thanks so much!!
Steve
Steve
Old 10-12-2017, 11:22 PM
KRviator's Avatar
KRviator KRviator is offline
Another option may be to use automotive seats.
I found Suzuki Swift seats fit almost perfectly in the RV-9, when you remove the steel frame you can slide the aluminium seat back in its' place and voila!
And testing them out for space available before I had an upholstery shop cut out space for the stick movement.
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A 19-8519 - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Phase I done. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
