Old 10-05-2007, 08:31 AM
CHEROKEE66 CHEROKEE66 is offline
Default Brake Return springs
I have seen it mentioned several times about having a spring return on the brake pedals. What tension or strength and length do they require? I am sure someone has done their homewok that did this and I would appreciate any info.
Thanks George Z
Old 10-05-2007, 09:09 AM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Default Parts List
RV Brake Spring Parts List
I used the following from McMaster Carr
www.mcmaster.com/
(1) Pkg 6389K625
Nylon Bearing Flanged, for 3/8" Shaft Dia, 1/2" Od,
3/8" Length, Packs of 5 $1.97 Pkg
(1) Pkg 9657K115
Steel Compression Spring Zinc-Plated Spring-Tempered, 3"
L, 1/2" Od, .047" Dia, Packs of 12 $5.29 Pkg
(4) Ea. 9946K13
Aluminum Set Screw Shaft Collar 3/8" Bore, 3/4"
Outside Diameter, 3/8" Width $1.82 EA.
for a total cost of about $19.62 with shipping.
Reiley
N622DR - Serial #V7A1467 RIP Aircraft Drowned in the 05/2015 Memorial Day Flood
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 10-05-2007, 07:44 PM
Thanks for the info, this is a great source of information.
George Z
Old 10-05-2007, 09:08 PM
briand's Avatar
briand briand is offline
If I understand correctly; the Cleveland master cylinders require the springs but the Matco's do not.
I could be wrong.
Old 10-06-2007, 01:56 AM
Rene Bubberman's Avatar
Rene Bubberman Rene Bubberman is offline
Default Matco needs 'em too
Here's a picture of the set-up: http://websites.expercraft.com/PHVII...y&log_id=19304
Better install them when the brakes are still easily accessable
René Bubberman
PH-VII | RV-7 | tip-up | FADEC
Flying | 480 hours
http://websites.expercraft.com/PHVII/
PH-RVP | RV-7A | slider
Flying | 5 hours
http://websites.expercraft.com/phrvp/
Old 10-06-2007, 03:01 PM
I could be wrong.
You have it backwards.
Matcos and Clevelands both have return springs, however the Matco has them internal and the Clevelands have them external...
But for some reason, the Matco units sometimes need a little extra, so a second spring can be added to the exposed shaft.
I have had both apart, side by side, and the main area I can see that might cause the problem is the "Free play" at the end of the return stroke. The Matcos have very little, and the Clevelands have close to a quarter inch of free play.
Old 10-07-2007, 02:59 PM
painless painless is offline
I just did this installation as a retro fit, and had no trouble adding the springs while under the panel.
Regards,
Jeff Orear
RV6A N782P
Peshtigo, WI
Old 11-17-2007, 10:44 AM
jlfernan's Avatar
jlfernan jlfernan is offline
How far down the shaft should the collar be? I'm looking for the best ompromise between peformance and pedal travel. Also, once the brake system is full, how much pedal travel should you have?
http://www.mykitlog.com/JorgeF
Jorge Fernandez
Spruce Creek, FL
Old 11-17-2007, 11:05 AM
My collars are about 3/4" from the top attach point of the master cylinders. This seems to give me enough tension to return the pedals to neutral with enough authority. No need to over do it, but your foot will compensate for any over loading of that spring IMHO.
As far as pedal travel, you really need to get a feel for the resistance you have in the brake. If you feel that it is spongy and has excessive travel, then you have air in the line somewhere. Once you bleed those lines, you should feel firm resistance to pedal application after about 2"of deflection...at least that is what I am getting.
Hope this helps
Jeff Orear
RV6A N782P
Peshtigo, WI
Old 11-17-2007, 03:26 PM
Default Are you sure?
Two inches is a huge amount of peddle travel for the brake peddles in any RV.
If the system is working properly with no air in it anywhere, the peddle travel should be more on the order of 3/4 inch maximum travel at the top of the peddle. That's been my experience anyway, with the dozen or so RV's I have worked on.
Scott McDaniels
Hubbard, Oregon
