Old 10-12-2017, 05:25 PM
rvdave rvdave is offline
Default SD20 won't fit
Just received my B&C 410H which I believe used to be sd20 but won't fit on my IO540 with the oil filter adaptor I have. Is there a simple resolution without having to redo oil filter?
Dave Ford
Cadillac, Mi
Old 10-12-2017, 05:42 PM
Default Not sure but...
Is this what you need?
http://www.bandc.aero/extensionforsd...homebuilt.aspx
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
Dues Paid 2017,...Thanks DR+
Old 10-12-2017, 05:49 PM
Not sure, they didn't mention that when we spoke. I have a spacer already, not sure if that is common to other engines? Also I don't know if the ofa is b&c or other? There's a number on it but will have to check.
Dave Ford
Cadillac, Mi
Old 10-12-2017, 06:46 PM
Looks like it's ECI, this is a Mattituck engine, so probably ECI ofa also. Looks not compatible with b&c?
Dave Ford
Cadillac, Mi
Old 10-12-2017, 08:05 PM
bcondrey bcondrey is offline
When you have the SD-20 (or newer 410) in combo with the B&C filter adapter you wind up with a spacer on both. Their oil filter adapter gets a 1.4" spacer to clear the engine mount and the SD-20/410 gets a .75" spacer and different shear coupling. It's pretty easy to change out the shear coupling and add the spacer yourself, just give them a call.
Bob
RV-10 #2 99.9% Complete
Old 10-12-2017, 08:07 PM
CDN CDN is offline
Default Second accessory pad
I'm not sure if it would work but my IO540 has another accessory pad on the aft, right bottom side of the accessory case. I think it was originally for a hydraulic pump and it looks to be the same size. Might be worth looking into.
VAF Donation made Feb 2018
RV-10 C-GNCX Flying and LOVING IT!
Old 10-13-2017, 09:24 AM
flion's Avatar
flion flion is offline
I had that problem with the tach sender interfering with the backup alternator. The hydraulic pad won't work for the alternator. I've finally got a tach sender with cable that works. My oil fiter adapter was no problem because I got the Airwolf remote filter and that adapter just clears the alternator by 1/8" (put the alternator on first). I know you don't want to mess with your filter setup, but if the extension does not work then at least you have an alternative.
Patrick Kelley - Flagstaff, AZ
RV-6A N156PK - Flying too much to paint
RV-10 14MX(reserved) - Fuselage on gear
http://www.mykitlog.com/flion/
EAA Technical Counselor #5357
Old 10-13-2017, 10:58 AM
Sounds like that's what I need, my engine came with a 2.5" ofa spacer so I do need to change both, confirmed and ordered thru b&c today.
Dave Ford
Cadillac, Mi
Old 10-13-2017, 02:23 PM
Default Alternator
Is that the 410 or 460 in the photo above?
Bob
Doors - Done
On Gear
290 HP Barrett Hung
Old 10-13-2017, 02:44 PM
flion's Avatar
Mine? It's the 462.
