Old 10-12-2017, 04:29 PM
KiloFoxtrot KiloFoxtrot is offline
Default FS: Two NEW ANDAIR Gascolators GAS375-F
I have two Brand New never installed Andair Gascolators GAS375-F.
Sell at $150 each, or if you want to buy both I will sell the pair for $280.
The gascolators that I have for sale have consecutive serial numbers.
The Andair Gascolator GAS375 has many great features.
1. Female fittings on both the inlet and the outlet.
2. All aluminum construction.
3. The filter bowl is sealed using an 'O' ring.
4. All Andair Gascolators can be sited either on the suction side or the pressure side of the fuel pump, our test Gascolator GAS375 was pressure tested to over 1000 psi before rupture.
5. The screen material is constructed from 70 micron Stainless Steel woven mesh coated in PTFE. This reduces the transfer of water and gives good filter performance. The pleated nature of the screen gives a very large screen area reducing the pressure drop across it.
6. The screen construction is robust and can be easily be detached from the main body and cleaned with an air line or washing in clean fuel.
7. One point that may be of interest, Andair Gascolators are now being used on certificated aircraft.
8. Easy to mount, either on the back of the gascolator or on the top using 1/4 UNF tapped holes.
Old 10-15-2017, 08:17 AM
stevebates stevebates is offline
Default andair
sent pm. Thanks
Old 10-15-2017, 09:51 AM
Default andairs
would like both of them
Old 10-15-2017, 10:31 AM
jwall jwall is offline
Default andair gascolator
sent you an email in regards to the andair gascolator. John
Old Today, 06:14 PM
Default Andair gasculators
Both have been bought. Original poster is traveling and possibly neglected to inform group. Thanks
