Old 10-11-2017, 11:04 AM
Rbb469 Rbb469 is offline
Default Need info converting a finished -7 to add a jettison canopy.
Iíve searched the forums but yielded limited results.
How difficult is this process to add to a flying aircraft?
Does vans sell a complete kit?
My center stack consists of (ADV AP, GTN 650 2nd com) with a ADV 5600(left) and a D60 as a stby (rt side).
Any info would be greatly appreciated. Thanks, Ricky
Dues gladly paid!
Old 10-11-2017, 01:20 PM
bret's Avatar
bret bret is online now
slider or tip up?
2018 gladly supported
Old 10-11-2017, 01:23 PM
Originally Posted by bret View Post
slider or tip up?
Itís a tip up.
Dues gladly paid!
Old 10-11-2017, 01:39 PM
Ralph Inkster Ralph Inkster is offline
You don't have a set of plans? The few parts required would be called out on them & the arrangement for installing also illustrated.
Difficulty would depend on how many parts the original builder omitted when putting the plane together, and how many components would have to be relocated on your panel to fit in the pull handle.
Ralph
Maintain lots, upgraded & repaired some, modified more, rebuild a few, & built 4 of 'em
Old 10-11-2017, 03:54 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Ricky as Ralph has mentioned that these parts are all listed in the plans. No Vans does not have a "kit" for the jettison handle and associated parts. Again as Ralph mentioned you'll have to verify exactly what is and isn't installed on the airframe. I do not know the depths of the equipment you listed so if they go thru the sub-panel where the jettison handle (and parts) are supposed to be (hence deletion of the handle and parts) then you'll need to relocate those. Pretty much a full panel / subpanel rebuild.
Here is DWG 47 for the 7 tip-up showing the parts needed to install. I would suggest that if you do not have the plans for this aircraft you order the CD from Vans. You should also ask for the instructions to this section of the build.
https://photos.google.com/album/AF1Q...yAoy36PVWWZE5p
Carlos in Arizona
EAA Chapter 538 President, www.538.eaachapter.org
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 10-11-2017, 06:52 PM
Thank you very much guys for your detailed explanations. I will start by contacting the builder and ask him a few questions, then go from there.
Again, thanks for your time and reply! Ricky
Dues gladly paid!
Old 10-11-2017, 09:00 PM
N941WR's Avatar
N941WR N941WR is offline
In addition to the parts listed in the drawings, you will have to cut the top skins above each hinge. Then add a light layer of fiberglass and paint to cover the slots.
Good luck with the mod and may you never have to use it!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-12-2017, 05:10 AM
ronschreck's Avatar
ronschreck ronschreck is offline
Default Wait!
The T-handle does not have to protrude through the instrument panel. You can use a Bowden cable or similar flexible cable to route the T-handle to any other place in the cockpit. This is a relatively easy mod to do on a finished airframe.
Ron Schreck
IAC Director and National Judge
RV-8, "Miss Izzy", 2100+ RV Hours
Track Me
VAF 2018 Donor
"He who demands everything that his aircraft can give him is a pilot; he that demands one iota more is a fool."
Old 10-12-2017, 06:31 AM
KatanaPilot KatanaPilot is offline
Default Pictures?
We are trying to implement such a mod on our RV-7A. The stock T- handle does not play nicely with our modern glass panel. A Bowden cable was what we had also thought to use. Rather than reinvent the wheel, if someone has done this already - pictures of the actual installation would be very helpful. Thanks in advance!
Krea Ellis
Locust Grove, GA
DA20-A1 Katana "Princess Amelia"
RV-7A Phase 1 still under way, out of paint at Evoke
RV-10 under construction
Old 10-12-2017, 06:52 AM
ronschreck's Avatar
Something like this would work well:
http://www.aircraftspruce.com/catego...s_thandle.html
Ron Schreck
Track Me
VAF 2018 Donor
