Old 10-10-2017, 07:05 PM
agirard7a's Avatar
agirard7a agirard7a is offline
Default Edges
I often cleaned edges with a belt sander then polished
With a 3m wheel. Very fast.
Al Girard, Newport, RI
N339AG
RV-9
Old 10-10-2017, 08:27 PM
wirejock's Avatar
wirejock wirejock is offline
Default Tool box
Looks good. Like the man said, drill it apart and do it again.
Only one tiny issue. Don't be bashful with the dimples. Hit the C-frame hard enough to leave a doughnut shaped burnish mark.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 10-10-2017, 08:28 PM
wjb's Avatar
wjb wjb is offline
Nice work, but you used the wrong primer.
(just a joke, if you're not familiar with Primer Wars...;-)
In the immortal words of Van's: "Build on!"
Bill Bencze
N430WB (reserved) RV-7 #74152, tip-up. Engine hung!
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2018 donation happily made
Old 10-10-2017, 08:36 PM
Mort04 Mort04 is offline
This is hilarious, I am well aware with the primer wars!!
Old 10-11-2017, 07:24 AM
flynwx's Avatar
flynwx flynwx is offline
One technique to avoid scratches is to leave the vinyl on the skins for as long as possible. You can use a soldering iron to score the vinyl on either side of the rivet lines. Then, you can peel the vinyl away from the rivet lines and leave the rest covered. I recommend a Scotchbrite wheel for polishing edges, and you can use the Scotchbrite wheel to round over the tip of the soldering iron that you use to score the vinyl.
Scott "Stormy" Weathers
N7WX (reserved)
wings
Old 10-11-2017, 02:02 PM
dave4754's Avatar
dave4754 dave4754 is offline
Default Looks good
order the kit and say good bye to life as you know it. Build on brudda!
Dave Cobb
=VAF=2018 Donation - and a bit extra for great work!
Empennage RV 7 - Tipper
Wings complete
Fuse nearing completion, Canopy complete
AME reviewed and repaired O-320-Lyc installed
Old 10-11-2017, 08:25 PM
wjb's Avatar
wjb wjb is offline
I posted somewhere else recently: I read a piece in RVator about a serial builder with shockingly short build times, < 1yr. One trick he did was to prime everything with an epoxy primer right out of the box ... plastic off, primer on, all sides. The primer held up well and he only had to do touch ups when he cut, countersunk, etc. Saved lots of time.
I didn't think to do this, but if I was starting over, I'd consider it. A weekend to prime most everything seems like a good use of time with lots saved down the road.
$0.02 worth of wisdom.
Bill Bencze
Old 10-12-2017, 03:49 PM
Hereís a question Iíve been wondering. Do you prime before fluting and dimpling too? Would the primer prevent a full dimple from forming, or will it collect primer if spraying after dimpling?
Old 10-12-2017, 04:19 PM
bkervaski's Avatar
Here’s a question I’ve been wondering. Do you prime before fluting and dimpling too? Would the primer prevent a full dimple from forming, or will it collect primer if spraying after dimpling?
Prime afterwards, primer shouldn't be so thick it affects the rivets. High build primer for example would be a bad choice for prepping parts.
.. be careful about asking questions about primer .. almost didn't reply for fear of 25 pages of arguments .. LOL
Progress: Flying!
Old 10-12-2017, 04:27 PM
wirejock's Avatar
Default Run for cover
Agreed but run for cover cux the flames are comin'!
Kidding. I think newbies should be encouraged to ask anything so ask away.
My processes are on my blog. Link in my sig.
Larry Larson
Estes Park, CO
Disclaimer
