Old 10-10-2017, 08:24 AM
mike newall's Avatar
Default Canopy Molding/Glareshield
As we are doing a 'posh' airplane, we are incorporating both the glareshield and canopy side moldings.
Does anyone have experience of installing these and in particular - which order to install them ?
Common sense would suggest fit the glareshield first, then fit the side moldings TO the glareshield at the front.
Suggestions welcomed.
Donated twice in 2017
Old 10-10-2017, 01:11 PM
Top Cat Top Cat is offline
Mike
Don't know if it makes a difference to your situation but when I ordered my SLSA, with the Autopilot Knobs panel that goes on the center instrument panel, Vans advised against glareshield as they said it would be a tight fit for fingers fiddling with the knobs. So I didn't add it.
PS. ex-pat whose family are all from Yorkshire...Middlesbrough and Middleton-In-Teesdale.
Old 10-10-2017, 03:50 PM
Jamesey Jamesey is offline
Default Local
Originally Posted by Top Cat View Post
Mike
Your nickname should have been “Parmo”
Old 10-10-2017, 05:02 PM
Parmo looks good but never had it myself. Parents families from that area but I’ve never lived there myself.
Old 10-11-2017, 04:31 PM
And yours would have been...........
I'll get me furry coat
Ta for the heads up btw - no knobs on ours - standard panels so will probably go with glareshield first, mouldings second.
Mike
p.s. If ANY of the Colonials get this, I will stand the drop of York... Oops, bit close to the knuckle Jamesey
Old 10-11-2017, 07:58 PM
Azjulian Azjulian is offline
I have both, glareshield is a perfect fit, no trimming I masked off my glue areas and painted the rest, then used fuel tank sealer to glue on (which I believe was specified in the plans)
The side moldings need a bit of a trim to get them right. I’d do the glaredhiekd then the side moldings
Old 10-12-2017, 02:27 AM
Thanks - appreciate the report
