Old 10-11-2017, 09:03 PM
Tony_T's Avatar
Tony_T Tony_T is offline
The parts are now on the web store list:
12 NOSE FORK CONVERSION ------ 325.00
12 NOSE WHL FAIRING CONVERSION ----- 20.00
Tony
RV-12 #202 -- Flying
Old 10-11-2017, 09:40 PM
Jetguy's Avatar
Jetguy Jetguy is offline
Everybody send me your old fork which I will be happy to recycle.
Ill even pay for shipping.
John
RV12 N1212K
Flying Since June 2010
1020 Hours as of 9/30/2017
Johnrv12@icloud.com
RV14 Wing, arrived and building at Rdog's new Hanger at 16X
S/N 140014
Old 10-12-2017, 10:25 AM
Thanks, Tony.
Jetguy, if I owned the shipping company Id take you up on that offer!😝
Old 10-12-2017, 11:55 AM
rongawer's Avatar
rongawer rongawer is offline
Tony, thanks for posting this. I'm motivated to implement the SB preemptively now. That's quite a difference in fork design - looks a lot more beefy.
Ron Gawer
- RV12, N975G, Phase 1 testing
- BE58, N1975G, stimulating the economy one flight at a time.
Old 10-12-2017, 05:24 PM
Tony_T's Avatar
Finished up the fairing conversion today.
The template included with the kit is for match drilling the new brackets for the mounting bolts.
Matching drilling brackets for the doubler rivets:
Dimpling and countersinking done for riveting the doublers, flush on the bottom. Some of the #40 holes are very close to the bend in the brackets and I had to grind some metal from the dimpling die to get those:
In order to make an easy job harder, I used a thin coating of fuel tank sealant between the brackets and the doublers. It looked like an area where moisture and corrosion would be likely:
The fork and fairing conversion completed and fits well, as expected.
Tony
Old 10-12-2017, 08:19 PM
PMLviator PMLviator is offline
Tony, I noticed weights on both sides of your nose wheel, did you have a bad shimmy?
Old 10-13-2017, 08:43 AM
Tony_T's Avatar
Shimmy? - You mean like a Cessna? No, the weights are just to balance the nose wheel.
Tony
Old 10-14-2017, 01:14 PM
DaveWelch DaveWelch is offline
Tony,
As always, very helpful and much appreciated!
RV12 N951DZ
First Flight 9/23/16!
No paint yet. Working on a scheme with John Deere colors or accents.
Old 10-14-2017, 02:00 PM
DHeal DHeal is offline
I see where Tony has attached his nose wheel balance weights to the rim of the wheel. I chose to place the self-adhesive weights inside of the wheel hub assembly so that centripetal force helps to keep them in place. There are three structural ribs inside the nose wheel that tend to get in the way of accurately placing the weights but it is doable. You can bend a slight curve in the weights so that they fit the inner surface of the wheel hub. I use a HF motorcycle balancing rig for my tire/wheel balancing and it works well.
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 650+ hours (as of July 2018)!
VAF donation through June 2019.
Old 10-17-2017, 02:27 PM
todehnal todehnal is offline
Originally Posted by Tony_T View Post
Installed the new heavy duty nose wheel fork. Easy work and no surprises. I used waterproof boat trailer grease on the bushings, new belleville cupped washers and a new bull nut.
Hey Tony!
I see that you replaced the belleville washers and the bull nut. Was this on principle, or did you detect a problem?
I was about to start my upgrade, when I noted that no belleville washers, bull nut, or fork swivel stop machine screws were included in the new kit. My plan is to have my RV-12 down for a short a time as possible. Should I order these? Anything else that I should order before starting that you an think of?
Thanks..........Tom
2013- RV12, Kit #119. N123M First flight Nov21. It's a keeper!
1998- RV-9 tail kit, built and sold
1989- RV-6 tail kit, built and sold
