Old 10-08-2017, 07:09 PM
JDA_BTR JDA_BTR is offline
Default Wiring harness oddities
I thought that the way the aileron trim kit was setup for the wiring jack on the assembly was wrong so I decided not to try and route the wire via the supplied connector slot. I cant figure what the designer intended at all.
Then I got the audio jack that goes with the wiring harness and there is no way to pass the connector thru the audio jack hole if made up in advance. I have to pass the jack wiring down through the cover plate then thru the hole in the fuse crosspiece there then attach the plug that mates to the wiring harness. Thing is it is setup so you canít take off the cover plate without cutting the audio wires even if you makeup that connector that supposedly would let you disconnect it.
Why is it done like that? I guess I donít ever need to pull that panel.......
N1463 seems a good number....
Old 10-08-2017, 08:18 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
Here is a previous thread on the subject: http://www.vansairforce.com/communit...-14+wiring+kit
Old 10-08-2017, 08:35 PM
Yes Iíve read that thread. Iím curious if Iím missing something useful in the setup Iím looking at.
One useful thing might be to enlarge the subpanel hole for the audio jack so that the connector can b passed thru and make that disconnect useful.
Old 10-09-2017, 08:01 AM
Jared_Solomon's Avatar
Jared_Solomon Jared_Solomon is offline
Why would you need to remove the audio jack, other than to replace it if it were broken? In which case it would be fine to cut the connector of the audio jack, and just install a new one.
Jared Solomon
A&P, EAA Technical Counselor
Powder Springs, GA
2018 Dues Paid
RV-14A (N214WJ) - Flying since Sept 2017
RV-7A (N211WJ) Flying since 2009 (SOLD)
RV-7A (N132RD) bought flying 2014 (SOLD)
KPUJ (Silver Comet Field)
Youtube channel: http://www.youtube.com/jmsolomon2000
RV-14 Build Log: http://rv14.jaredsolomon.net
Old 10-09-2017, 03:44 PM
The way the access plate is installed requires the jack to go with the plate.
