Old 10-07-2017, 08:05 AM
RVdreamin RVdreamin is offline
Default Fuselage question
I am preparing to disassemble fuselage for deburring, dimpling etc. my question is riveting the firewall to the forward bottom and side skins. I am lookin at the preview plans to see how the cowl fits to the fuselage, but can't seem to make sense of how the cow fits except for using a hinge. But what does the hinge fit too. What should I rivet on the firewall now?
Jimmy Black
Started Emp 10/9/2013 Finished 10/16/14
Wings finished April 9, 2016
Fuselage received Sepember 12, 2016
VAF paid 2017
Old 10-07-2017, 08:10 AM
nilberg nilberg is offline
On my RV-7 (same fuselage dimensions) I have no plans to rivet anything on the firewall flange until I attach the cowling.
Old 10-07-2017, 08:14 AM
scottmillhouse's Avatar
scottmillhouse scottmillhouse is offline
Look again. You must fabricate the hinge pieces and spacers to off set the hinges in to provide for the fiberglass cowl thickness. These need to be drilled, deburred and countersunk before riveting them together with the side and bottom skin and firewall. Do make sure to trim the stainless steel firewall edges back before assembly to match the side skins. If you don't it will be very hard to do and protect your nice side skin edge prior to riveting and impossible after.
There are good reasons to do before cowl fitting. Attaching the hinges eliminates clecos in the way and securely fits everything for a good fit and alignment. The cowl part of the hinge provides support and positioning for cutting and fitting the cowl. I've done three cowls that way so far.
Scott- 2018 dues paid
Got medical back, now building a 7A.
RV-12 #120515, 319RV over 210 hours.
1st flight 12/08/15, flew SNF, Oshkosh, Triple Tree & SERFI in year 1!
RV-9A, 536 hours, sold, RV-7 sold, Kitfox sold
Old 10-07-2017, 12:05 PM
rapid_ascent rapid_ascent is offline
I agree it's a little confusing about what exactly needs to be done while attaching the forward side skins. I'm in process at that stage. So far I've left some of the forward rivets out in addition to the firewall rivets. I was trying to figure out about firewall sealant too.
Ray Tonks
2018 Donation Paid
RV-7 Fuselage in progress
* Fwd Fuselage Complete
* Mid Fuselage Complete
* Aft Fuselage Complete
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
Shop Setup - In Progress (Gathering Tools, Never Complete)
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
