Old 10-06-2017, 12:52 PM
zn105 zn105 is offline
Default FS ADSB IN & OUT and Garmin GTX327 transponder $1800
I am selling my Uavionix Echo UAT ADSB out and wifi in solution as well as my Garmin GTX327 transponder. Echo UAT comes with antenna with coax and WAAS gps unit with antenna all approved for 2020 compliance in light sport or experimental. This unit listens to your transponder for pressure altitude and squawk code. The GTX327 comes with mounting tray, connector and antenna. Uavionix four months old and the GTX327 is very clean. $1800 for both! Patrick zn105@yahoo.com
Old 10-06-2017, 01:18 PM
N729LS's Avatar
N729LS N729LS is offline
Would be interested in the EchoUAT if you are considering splitting them.
Andy Elliott, CFI, RV-8, N303RV
Flight Reviews, Dynamic Prop Balancing
KFFZ, Mesa, AZ
Old 10-06-2017, 02:35 PM
2nd in line for the Echo UAT if you sell separately. You can PM or email me.
Hinckley, Ohio
PPL - 1970
RV-12 E-LSA #120058 AWC 7/12 Bought Flying 10/2015 with 48TT - Hobbs now 306
Old 10-06-2017, 03:54 PM
RicoB RicoB is offline
If you don't mind answering, why are you selling this setup? I just installed the echo and i have the same set up as you!
echo and the gtx-327.
My rv9 is not flying yet i got about 3 months still. Could you send me screenshots of your echo setup on the app. If yours is working good means i can just copy that same setup and mine should work. thanks
If you could email to ricostunts@gmail.com
Rico Burgos
RV9a - Building with a partner (avionics 99% done, Baffling in progress.) Planning to have it flying by the end 2017
Based at KWHP (CA)
C-150 Based at KMOD (CA)
Old 10-06-2017, 04:20 PM
It works great but I just picked up a Garmin GNS480 that has a GYX33 temote transponder. (ADSB ) I can send you a screen shot but I have to go to plane and connect to it for the app to show the settings. Do it tomorrow and send it to you.
Old 10-06-2017, 11:14 PM
That'a fine! no hurry. Thanks so much!!
Rico Burgos
Based at KWHP (CA)
Old 10-10-2017, 02:30 PM
rcarson rcarson is offline
I am interested in the 327 if you still have it for sale. Will send you a p.m.
Old 10-10-2017, 02:48 PM
Sold both, thanks for the replies.
