Old 10-06-2017, 08:23 AM
JackinMichigan's Avatar
JackinMichigan JackinMichigan is offline
Default Fuel line leaks - how to find them.
We recently had to replace a number of fuel lines in some very hard to reach areas (in the forward part of the tunnel). After completing this arduous task we leak-checked the system by capping off the wing tubes and pressurizing the system with air thru the firewall to 50psi.
With an artist brush and a bottle of children's soap bubble compound I painted all the fittings and could not see any foaming anywhere, but the system pressure dropped about 3psi over 30 minutes. We decided to leave it overnight, and this morning it was down to 20psi (approx. 14 hours later). The total volume involved is equivalent to probably 12 feet of 3/8" aluminum tube.
Does anyone have any tips on how to locate such a slow leak? Soapy water, a flashlight and an inspection mirror don't seem to be cutting it.
Jack and Dave Groat, father and son
RV-10 N1861G
Build #41389, started Oct 2012
Current status: 1st Flight 11/10/17
Old 10-06-2017, 09:24 AM
638RS's Avatar
638RS 638RS is offline
Default Talcum powder
Put on a light dusting of talcum powder. It will turn bright blue in the presence of av gas. You can vacuum up the residue when finished.
Richard
Portland, OR RV-7A
Last position
Last track
2017 Dues paid
Old 10-06-2017, 10:01 AM
snopercod's Avatar
You can "diaper" each fitting with paper towels and pressurize the system with AvGas. The diaper that turns blue is your culprit.
As for dealing with a bad flare, you might try a Del Fitting Seal rather than re-making a piece of tubing.
(2018 dues paid)
Old 10-06-2017, 10:06 AM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
Your post sounds like you believe you have a leak even after you leak tested with soapy water. Why do you think you have a leak? If you are basing that decision on the psi change note that the leak detection is NOT watching to see if the pressure in the lines decrease or not. The leak detection process is the soapy water and looking for bubbles.
The pressure within your lines can move up or down solely based upon the temperature and baro pressure in the environment from one day to the next. So, it is erroneous to think of the psi change as indication there is a leak. If you have concerns about leaks, test with the soapy water again. In fact, do it multiple more times until you are satisfied. Just don't automatically assume you have a leak because the pressure dropped.
RVBYSDI
Steve
RV9A
Live Long And Prosper! 🖖🏻
Old 10-06-2017, 10:29 AM
I can see barometric pressure or temperature changes accounting for maybe a 10% change, but a 60% change tells me air is escaping, just not fast enough to be readily detectable with the soapy water test (these fittings are in a difficult to reach area hard against the floor, so it may be easy to miss some foaming). It was my hope to eliminate all leaks, no matter how slow, before reintroducing AvGas. I just need to pinpoint them.
RV-10 N1861G
Old 10-06-2017, 10:32 AM
RVbySDI's Avatar
I understand your reluctance to introduce fuel into a leaking system but it does sound like the previous two suggestions could quickly find your leak source.
RVBYSDI
Steve
RV9A
Old 10-06-2017, 10:47 AM
digidocs's Avatar
digidocs digidocs is offline
Hi Jack,
If you haven't already, check the seals on the fuel valve. They aren't always designed to hold more than a few psi of pressure.
David
Old 10-06-2017, 11:28 AM
rocketbob's Avatar
rocketbob rocketbob is offline
Pressurize with compressed air and use a mechanic's stethoscope to look for the leaks. Works well.
Bob Japundza CFI A&PIA
N55BC RV-6 borrowed, flying
N678X F1 Rocket, under const.
N244BJ RV-6 "victim of SNF tornado" 1200+ hrs, rebuilding
N8155F C150 flying
N7925P PA-24-250 Comanche, restoring
Don't believe everything you read on the internet. -Woodrow Wilson
AlexPeterson's Avatar
AlexPeterson AlexPeterson is offline
Is the gauge perhaps leaking? Soapy water is about as sensitive as it gets. The large viscosity difference between air and avgas might prevent a leak of air into fuel or fuel into air, due to the surface tension.
Alex Peterson
RV6A N66AP 1600+ hours
Maple Grove, MN
Old 10-06-2017, 12:13 PM
That was the first thing we checked. Several times.
It's quite possible I'm taking this further than it needs to go, but if there's improving to be done I want to do it.
RV-10 N1861G
