Old 10-05-2017, 08:32 PM
Bootscooter's Avatar
Bootscooter Bootscooter is offline
Default VPX Mount
Hi All,
Just wondering where others have mounted a VPX in the panel.
Anyone have a pic of their installation?
Rgs Chad
Chad Boot
RV14 140331 VH-VNX. Flying
RV10 Standard Fuselage Complete
RV10 Empennage complete
RV-7 Slider Flying VH-VNZ
Sports Aircraft Assn Australia. Tech Councillor.
2018 Dues Paid
Old 10-06-2017, 06:13 AM
219PB 219PB is offline
I mounted mine is such a way that it gives some rigidity to the subpanel. This support was needed for the throttle and propeller controls. Also by removing two bolts the unit will be able to swing down for accessibility.
I then mounted EFII's Bus Manager on top of it.
Bottom view
Paul Bonorden
RV-6A under construction
My Builders Website
Victoria, TX
2018 Dues Gladly Paid
Old 10-06-2017, 06:17 AM
ColoCardinal's Avatar
ColoCardinal ColoCardinal is offline
Not sure how this would relate to your 14 but in my 7, I made a few mounting rails from 3/32 x 3/4 angle that spanned from the firewall to the next aft (middle) former then mounted the VPX upside down. Wherever you mount it, keep in mind that you may need to access it again in the future, after the plane is buttoned up. Install it so it can be acceessed / removed from below.
Carl - - Morrison, CO
N16CB will fly this year!
Paint booth built and in operation. final fitting of everything soon. Inspection in June?
paid 'til 10-18
