Go Back   VAF Forums > Model Specific > RV-4
Old 10-02-2017, 12:00 PM
diamondjim diamondjim is offline
Default RV 4 air intake old vs new
Can anyone tell me the pros and cons to the newer style snorkel opposed to the older flat style. I am looking at an older 4 and it has the flat style air intake. I was wondering if anything can be done or should be done with it. If so does anyone make a kit or can I just make a snorkel. Thanks
Jim
Old 10-02-2017, 01:11 PM
AX-O's Avatar
AX-O AX-O is offline
Can you be a little more specific? Carb or fuel injection? Vertical or horizontal induction? What does the "newer style snorkel" look like?
What do you consider old? The early RV-4 did not have a specific design. Most were home made by the builder.
Axel
RV-4 fastback thread and Pics
West Coast Ravens
VAF 2018 paid VAF 704
The information that I post is just that; information and my own personal experiences. You need to weight out the pros and cons and make up your own mind/decisions. The pictures posted may not show the final stage or configuration. Build at your own risk.
Old 10-02-2017, 02:19 PM
0320 built in 89 , has just a flat area where the intake is. Trying to figure what would be more advantageous. Sorry for the lack of info it's in an rv I am looking to purchase.
Jim
Old 10-02-2017, 06:48 PM
AX-O's Avatar
Can you post a pic? Is the flat area on the cowling or the "airbox".
Nothing is too difficult to change. But it may require re-painting.
Axel
West Coast Ravens
Old 10-02-2017, 07:15 PM
Also, why do you want to change it? Is there some specific goal in mind?
Old 10-02-2017, 08:02 PM
Wanting to have the best set up, I figured there must have been a reason they changed the design. I don't have a good picture of the carb air intake. Will update when I do. Thanks
Old 10-02-2017, 08:34 PM
Saber25's Avatar
Saber25 Saber25 is offline
Here is the original -4 intake. Early kit 1150 completed in '89. Straight inlet, no filter, very efficient and used with updraft carb. Works good lasts a long time.
Cheers, Hans
Build 'em light, keep it simple
I'd rather fly than tinker.
"There's a big difference between a pilot and an aviator. One is a technician, the other is an artist in love with flight."
- Elrey B. Jeppesen,
Old 10-03-2017, 07:21 AM
YellerDaisy's Avatar
YellerDaisy YellerDaisy is offline
Hi Jim, I think you are talking about the squarish inlet style like on a Cessna 140 (and others). I'm no expert but I think the difference is that the newer design offers a tiny bit more ram air effect, possibly better airflow behavior (into the engine), and possibly better filtering. I believe those are all insignificant to typical recreational flying. The most significant difference, IMO, is that the newer design looks better.
JD
RV-4 - O-320
RV-3B - O-320 - "Daisy" (sold)
http://jdfinley.com
Old 10-03-2017, 07:43 AM
Old 10-03-2017, 07:47 AM
You are correct, it doesn't have the small snorkel like the pic above. It is the square 140ish style opening. I wondered if the snorkel would be more streamlined and flow better.
