Old 10-04-2017, 06:28 PM
Not to get off subject, but if the rudder bolt - nylon nut could come lose, couldn't the flaps or aileron bolt - nylon nuts come lose?
I have my rudders done with a castellated nut and cotter pin as per plans and my ailerons with the nylon lock nut as per plans. Should I be worried about them? After reading this thread, it gives me cause to rethink the wings.
rockwoodrv9a
Meridian Idaho
rockwoodrv9a@gmail.com
O-320 D2A
Awaiting DAR Inspection
Old 10-04-2017, 07:49 PM
Sam Buchanan's Avatar
been here awhile
Rod end bearings do not require a castellated nut and cotter pin because the fitting gets torqued up tight against the ball of the bearing. The bolt and bearing ball do not rotate--the bearing race rotates on the secured ball of the bearing.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 10-04-2017, 08:41 PM
Thanks for the answer Sam. That makes sense.
rockwoodrv9a
Meridian Idaho
O-320 D2A
Old 10-04-2017, 08:56 PM
PCHunt PCHunt is offline
If you are really worried about it, check out:
MS17826 nut
It is both self locking (nyloc) and castellated.
http://www.aircraftspruce.com/catalo...clickkey=42362
http://www.gen-aircraft-hardware.com...&Submit=Search
Probably overkill, but peace of mind for some.
Or put a lock nut on top of a nyloc.
I personally think that in this particular application, it is more likely that a cotter pin will get damaged and fall out leaving a castle nut loose, than it would be for a new self-locking nut to come off.
Flame suit on.
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2018 Donation Plus, Gladly Sent
