Old 09-28-2017, 11:36 AM
laz laz is offline
Default rv8 rear canopy stop
I am finishing up my RV8 and have been unable to find any information on this forum or in the instructions regarding a rear canopy stop to prevent the canopy from hitting the rear stab fairing. What am I missing?
Old 09-28-2017, 11:45 AM
DonPro DonPro is offline
I used black plastic irrigation tube from Lowes or Home Depot. Cut to length and push it inside the slider track on both sides.
Don Prosise
N642DP RV-6 180,CS,Flying
N848DP RV-8A IO-360-A1A Flying
Chandler, AZ
Old 09-28-2017, 12:48 PM
lucaperazzolli's Avatar
lucaperazzolli lucaperazzolli is offline
I did the same, but the tube is transparent
Luke
Trento, northern Italy
RV-8 QuickBuild, Catto 3 blade Prop, YO-360-A1A. Status : I-LUKE is Flying - 300 h. and counting
http://www.rv8.it
=VAF= 2018
Old 09-28-2017, 08:02 PM
Go Guy Go Guy is offline
Default Canopy Stop
I used a piece of garden hose. Works great. Just figure out where you want the canopy to stop, measure the distance in the track rail from the roller to the end of the track, cut the hose and push it in. your done. I just put one in one side.
Rod Estep
RV8, BPE IO-360, C/S
5yr build, 10yr Flying
Still Grinning!
Dues Pd
Old 09-28-2017, 08:11 PM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Default Ditto
I used black fuel lint in the channel, makes a great stop.
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
Olympia, WA
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2017
Old 09-29-2017, 08:08 AM
laz laz is offline
Thanks to all. I used some rubber that I cut to fit inside the channel.
