Old 09-26-2017, 03:31 PM
HAL Pilot's Avatar
HAL Pilot HAL Pilot is offline
Default Pg 10-05 Match drill #40 Oops
Got distracted and ended up drilling # 30 Holes. On the subpart of step 1.
I'm thinking just 4-6A screws. Any one see any issues w this?
Pete
Pete
RV14A Tail kit build in process
RV 14 WIKI in process, residing on Drop Box
https://www.dropbox.com/sh/xu5p6f4l7...bU0ck0pJa?dl=0
---For Edit Access drop me a PM with your Email address.
EAA 1300
Donation Paid 2018 (Military exempt) Cause its worth it.
Old 09-26-2017, 04:05 PM
Not building a -14, so don't know what you're joining. Some structural joints depend on the expansion of the rivet to lock the parts against movement in shear. Bolts & screws don't typically fit tight to start, and the diameter shrinks slightly when torqued.
I made a similar mistake (over countersunk) on my spar, & Van's ok'd going to larger rivets as long as I avoided knife-edge at the bottom of the countersinks.
Old 09-26-2017, 06:44 PM
Tom023 Tom023 is offline
I believe those two holes get sized for AN3 bolts anyway so i would do a quick check with Vans. As a side note, I have a few AN3 bolts in place of rivets due to mangled holes on difficult rivets. Not ideal but Neither Vans nor my tech counselor had any issues with their use.
RV14A #140083
Wings, empennage, fuselage and finish slow builds completed. Avionics Installed.
FWF in progress (temporarily on hold after unexpectedly having to move from T51 to KDWH)
2017 Donation
Old 09-26-2017, 07:26 PM
mikerkba mikerkba is offline
Default Oops rivets
Did you know about these, actually called "oops rivets" for this situation and other applications. 3/32 rivet head on a 1/8 rivet shaft. Search on "oops rivets" and find multiple sources and articles. Here is one entire kit with a variety of them, though you may just want to acquire a few of the specific ones you need:
http://www.aircraftspruce.com/catalo...ts12-03781.php
Mike Coster
BUILDER: N92MB RV7A (A/W 3/2009) - Sold
ADOPTED/reworking: N4032Q RV8A (8/2017)
KELY/Ely, NV
Old 09-26-2017, 10:21 PM
HAL Pilot's Avatar
Sorry I should have been more descriptive. The holes are for AN-3 bolts. And you are correct they do get drilled out to AN-3 size later so I guess I got ahead of myself.
Pete
Pete
EAA 1300
Old 09-28-2017, 01:28 PM
Jared_Solomon's Avatar
Jared_Solomon Jared_Solomon is offline
Thumbs up Build on
You should be fine. You'll be drilling those to final size on Page 10-27. You'll be back drilling through the vertical stab, into the F-01412C deck angle.
Jared Solomon
A&P, EAA Technical Counselor
Powder Springs, GA
2018 Dues Paid
RV-14A (N214WJ) - Flying since Sept 2017
RV-7A (N211WJ) Flying since 2009 (SOLD)
RV-7A (N132RD) bought flying 2014 (SOLD)
KPUJ (Silver Comet Field)
Youtube channel: http://www.youtube.com/jmsolomon2000
RV-14 Build Log: http://rv14.jaredsolomon.net
