Old 09-25-2017, 01:47 PM
Gizmos Gizmos is offline
Default Installation of aileron servo after wing is built?
How hard is it to install aileron servo in the wing of RV-9a after the wings are covered? Should I just install it under the copilot seat? I did this for my old RV-6a and it worked great
Old 09-25-2017, 02:19 PM
scott08 scott08 is offline
I tried installing under the seat of my 8A but the previous builder had put the trim mount right where the bracket needed to go. I believe the was also another conflict with that area. I opted to place it in the wing, no issues at all. I was able to fish the wires down the wing conduit and run through the fuselage to the panel. This is provided you have a conduit in your wing and enough space to get wires through the spar. It took some very time consuming solder and tape prep to get everything to pull correctly with minimum increase in diameter.
Old 09-25-2017, 03:46 PM
Zuldarin's Avatar
Zuldarin Zuldarin is offline
Which servo? Trim or Autopilot?
I installed the autopilot servo (Garmin) in the wing after the wing was covered and it was relatively simple. My trim servo in in the fuselage under the seat pans.
Darin
Snoqualmie WA
RV-9A Flying as of 03/2015
RV-10 Building - Wings - Flaps/Ailerons
www.DarinAnderson.com
2018 donation sent!
Old 09-25-2017, 04:42 PM
Default Garmin sa 28
It's the garmin sa28 autopilot servo, I made a mount where the manual trim for the ailerons was installed and use a Ray Allen servo. Just did not know how hard it was to install the sa28 in the wing. I will do a coupling under the copilot seat for a/p aileron thanks
Old 09-25-2017, 04:45 PM
Dbro172's Avatar
Dbro172 Dbro172 is offline
The gas 28 servo can be installed in a completed wing, through the access hole, using the Garmin bracket, in about 30 minutes.
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
www.mykitlog.com/dbro172/
1968 Mooney M20C - Sold
1956 C-182 - Sold
Old 09-25-2017, 06:09 PM
guccidude1 guccidude1 is offline
Default nstallation of aileron servo after wing is built?
I installed the Dynon (True Track) aileron servo twice, first the -32 but it slipped in cruise, and then the free swap out -42. I found the install straight forward but tight. The safety wire is the worst, but if you're naturally good looking, I found it most doable. Dan from Reno
Old 09-25-2017, 07:00 PM
XPPilot XPPilot is offline
Default Dynon / True Track A/P servos
Are you saying that Dynon and TruTrak Auto Pilot servos are same? In other hand can I connect my TruTrak servos directly to Dynon D180 and leave TruTrak control heat out?
Old 09-25-2017, 07:33 PM
johnbright's Avatar
johnbright johnbright is offline
Default Dynon vs Trutrak servos
Mechanically yes, electrically no... FAQ #6
John Bright, RV-6A 25088, at FWF
O-360, 8.5:1, vert sump, SDSEFI EM-5
Z-14 adapted for EFI, wiring and IP CAD files here
Newport News, Va
Old 09-25-2017, 08:50 PM
Jesse's Avatar
Jesse Jesse is offline
Originally Posted by johnbright View Post
Physically about the same size, but substantially different mechanically and electrically. The Dynon servos have brains in the servo that talk to the D180 or Skyview, etc. The TruTrak is basically a dumb servo that gets all commands from the programmer including torque, direction, speed, etc. The TruTrak servos will not work without a TruTrak programmer/Head.
352-427-0285
jesse@saintaviation.com
Old 09-25-2017, 08:53 PM
Jesse's Avatar
In a -9/A, the servo fits best in the wing and is very easy to install after the wing is closed. Easiest if he wing is on a stand, but still easy if the wing is mounted on the plane.
352-427-0285
