Old 09-24-2017, 09:52 PM
jcarne's Avatar
jcarne jcarne is offline
Default Left tank fuel float question
Good day everyone, I am working on my fuel tanks and was wondering what most of you did with mounting the left tank fuel float with a flop tube. The plans are kind of cryptic here. My question is, did you attach nutplates directly to rear baffle or did you make a doubler to help support the sending unit? It seems that the plans show no doubler but the rear baffle is significantly thinner than the access plate one would normally mount the sender to. Thanks!
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Working on Fuselage
Finish kit on order
Exempt but gladly paying!
Old 09-25-2017, 09:48 PM
VA Maule VA Maule is offline
Just finished 2 leak free ( so far fingers still crossed) tanks for my 8, I added a 0.32" doubler due to the thinness of the baffle
The Best Government is less Government
Maule MXT-7(daily flyer)
Lancer 235(partner)
Raidial RV-8R Ephanage Done, Wings Done, Fuselage underway
Old 09-26-2017, 08:55 AM
fritzg fritzg is offline
I made a doubler out of the unused inspection cover and installed on the inside of the baffle. Not sure if this is necessary but it took less than 10 minutes and cannot hurt.
Old 09-26-2017, 06:08 PM
jcarne's Avatar
Thanks for the replies guys. I was thinking I would go ahead and make a double but wanted to see if others thought it was unnecessary.
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Working on Fuselage
Finish kit on order
Old 09-26-2017, 07:03 PM
KatanaPilot KatanaPilot is offline
Sent you a PM. I have some pictures of this mod we did at Synergy a couple of months ago on an already built tank. Don't know if that will help you.
Krea Ellis
Locust Grove, GA
DA20-A1 Katana "Princess Amelia"
RV-7A Phase 1 under way, in paint at Evoke Aviation
RV-10 under construction
Old 09-27-2017, 10:00 PM
jcarne's Avatar
Thanks Krea, I sent you an email from my gmail account. Let me know if you don't get it.
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Working on Fuselage
Finish kit on order
