Old 09-24-2017, 04:06 PM
Chris Cooper Chris Cooper is offline
Default Elevator trim tab play
Fixed the elevator trim tab to the hinge and attached the motor and actuator. With the clevis pin in place I have about 0.5mm of play. The pin is very slightly loose in the trim tab horn. Is this acceptable?
Old 09-24-2017, 04:26 PM
After couple thousand hours of flying I had considerable play in elevator trim tab due to an elongated hole. I fly an RV9A. A good friend of mine machined a bushing out of a rivet. Fits perfect feels tight. Thanks Julian!
Old 09-24-2017, 05:01 PM
F1Boss's Avatar
F1Boss F1Boss is offline
Default "No"
I think the consensus would be "no - get it fixed". There are various ways to bush the hole in the arm to get a better fit at the pin.
Good catch, by the way!
Best,
Old 09-24-2017, 07:08 PM
brad walton brad walton is offline
When you say 0.5 mm play, is that at the trailing edge? I had about a 1/16 inch play at the trailing edge after 390 hours. I found the trim tab hole was about 3 one thousands inch larger than the clevis pin diameter. After reading your post, I fabricated a press fit clevis pin and now have no trailing edge play. I will be interested to see if its easier to hold altitude accurately.
Old 09-24-2017, 07:15 PM
vluvelin vluvelin is offline
Any time comaradishe!!!!
RV7 C-GLLT - FLYING
RV7 C-GZZY- NOTFLYING
2017 June RV7 Emp in works!
VAF SUPPORTER
2014, 2015, 2016, 2017, 2018
Old 09-25-2017, 01:25 AM
Yes, at the trailing edge.
Old 09-25-2017, 09:29 AM
If my math is correct .5 mm is less than .020 "
.020 " free play at the the trailing edge is totally fine.
Scott McDaniels
Hubbard, Oregon
Old 09-25-2017, 09:33 AM
Thanks for all the replies. Is there a limit for this?
Old 09-25-2017, 10:00 AM
In service experience and GVT testing (on an airplane that for the test had ~ 1/16" play) has shown it to not be very critical with even quite a bit of play assuming aircraft VNE limits are complied with.
I think a conservative limit would be .032 or 1/32".
Scott McDaniels
Hubbard, Oregon
Old 09-25-2017, 12:00 PM
MED MED is offline
A millimeter is actually 0.03937 inch - interestingly, the same number as the number of inches in a meter. For quick calculations, for those of us who must make the conversion in our head, because we don't think in metric, we always just use 0.040 inch (40 mils) as "close enough for government work."
MED
140236
N435MD reserved
