Old 09-20-2017, 02:56 PM
mfleming's Avatar
mfleming mfleming is offline
Unhappy Edge Roll after dimpling?
OK...
So I got over enthusiastic and dimpled some of my wing skins before I used my Cleveland edge forming tool to break the edges that overlap.
Am I out of luck, or is there a way to break the edge after dimpling?
(I searched but didn't find an answer)
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Donated 2017
Old 09-20-2017, 03:02 PM
ILikePike ILikePike is offline
I hate it when that happens. Use a hardwood block with a shallow slit to carefully roll the edge. Compare your work to a properly rolled edge as you go.
Jeff Green
2016 RV-8 #82985
1968 E33C Aerobatic Bonanza
Pleased to donate Dec 2017
bkervaski's Avatar
You can use the Avery tool and get it pretty close, I did exactly the same thing on one of my skins, it turned out fine (you can't even tell) but I couldn't get the Cleveland Tool to work because of the dimples.
https://www.aircraftspruce.com/catal...ickkey=1877164
Progress: Away for PAINT
Old 09-20-2017, 03:14 PM
Nova RV Nova RV is offline
Use your Cleaveland tool between the rivets and then match the edge break with an Avery tool or hand seamers at the rivets
Chris Moon
Leesburg, VA
RV-14A kit # 140243
VAF 2017 and 2018 paid
www.mykitlog.com/chrismoon/
Old 09-20-2017, 03:50 PM
Stoo Stoo is offline
Happened on one of my skins too! I used the Cleaveland tool. Start with it loose and tighten it down over several passes. Redimple the holes when you are finished. Came out just fine (to my surprise!).
Stewart Willoughby, 6 panel/wiring.
Old 09-21-2017, 10:30 AM
mfleming's Avatar
VAF is a great site!
Thanks for all the tips. I ordered the Avery edge roller from Cleaveland Tools yesterday.
I have plenty of edges to break so I'll probably use several of the suggestions.
Michael Fleming
Joseph, OR
RV-7 Slider #74572
Started 11/2016
Donated 2017
