Old 09-17-2017, 03:56 PM
Tom023 Tom023 is offline
Default Landing Gear Toe Alignment
Today I installed the landing gear, axles and measured for correct toe alignment using Vans method. The right is toe in 0.8 degrees, easily correctable with a 0.75 shim. The left however is toe in 2.2 degrees, off the provided chart. I'm a little disappointed in this as everything thus far in the kit has been spot on.
I'm just curious what othes have seen for their measurements. I loosened the left gear and wiggled it a bit and retorqued with no change. I suppose I can stack three shims (0.75+0.75+0.5) but not sure that is acceptable but will call Vans in the morning. I would rather pay the $75 for three shims than wrestle with all the tight bolts holding it in to replace the leg.
RV14A #140083
Wings, empennage, fuselage and finish slow builds completed. Avionics Installed.
FWF in progress (temporarily on hold after unexpectedly having to move from T51 to KDWH)
2017 Donation
