Old 09-15-2017, 10:03 AM
amirgreenfield amirgreenfield is offline
Default RV-14 inverted flight
Anyone can tell me anything about inverted flight fuel supply in RV14?
Old 09-15-2017, 01:33 PM
mill2978's Avatar
mill2978 mill2978 is offline
Default Are you going with a stock FWF?
It depends on what you plan to install FWF.
A friend's RV-14 has the EFII system, this uses dual electric fuel pumps. As far as fuel goes as long as the fuel tank has a flop tube for pickup the rest of the EFII system doesn't care/know it's inverted.
Are you looking for sustained inverted flight or sportsman level aerobatics?
Aaron Miller
RV8 N127KT -Reserved
Tail feathers done except for tips
Wing kit 85% complete
Fuselage in progress
Dues Paid 2015
http://www.mykitlog.com/AaronMiller/
Old 09-15-2017, 05:09 PM
TASEsq TASEsq is offline
I read on here that you can't put a flop tube in the -14 tanks (but I can't remember the reason!).
Old 09-16-2017, 09:40 AM
czechsix's Avatar
czechsix czechsix is offline
I wonder if you'll be happy with how the -14's airfoil works inverted. I recall years ago hearing Van say that one reason he selected the 23000 series NACA section for the 3/4/6/7/8 models is because it works reasonably well inverted. I suspect the -14 airfoil won't do too well inverted since it had very different design goals (originally designed for the -10). Anybody have any data points on how it flies inverted?
The mission of the 14 is more geared toward comfortable XC and oh by the way you can also do loops, rolls, and spins, but if you're wanting to do more serious acro including negative G I'd recommend a 7 or 8.
Mark Navratil
Spring Hill, KS
RV-8A N2D #80583 - built/flew/sold
RV-14A #140017 - wings complete, empacone in progress...
Old 09-18-2017, 10:00 AM
Erimo's Avatar
Erimo Erimo is offline
I asked to Van's the same question. The answers were : the fuel tanks don't accept flop tubes and the '14 pass the positive G aerobatic figures. So any fuel and oil inverted system is required.
Old 09-20-2017, 06:35 AM
bkervaski's Avatar
I don't think you need anything beyond stock for occasional loops and rolls?
.. which brings up the question on how to keep the stock brake reservoir from leaking ..
Progress: Away for PAINT
Old 09-20-2017, 07:01 AM
It isn't an issue on gentleman's aerobatics.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 09-20-2017, 07:08 AM
M McGraw's Avatar
M McGraw M McGraw is offline
Default Brake reservoir
Contact Alex Peterson for a check valve that screws into the top of the reservoir. I think he calls it a Reservoir Dog. Could be wrong on the name, I bought mine a few years ago.
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 175+
2018 Dues Paid
Old 09-20-2017, 07:10 AM
bkervaski's Avatar
Okay, that's a fantastically simple mod, thanks!
http://reservoirdog.alexap.com/index.html
Old 09-20-2017, 08:43 AM
If the aerobatics you are doing are all positive G's (required to keep the engine running and healthy if no inverted fuel and oil system is installed) then there is no need to do anything different with the brake reservoir cap.
The same (positive G) forces that keep the oil and fuel in the proper place will do the same with the brake fluid as well.
BTW, an inverted fuel pick-up capability was never planned for the design of the RV-14 because its primary mission profile is cross country travel with the ability to get upside down occasionally if desired (for 99.9% of people that means positive G's aerobatics only).
The standard fuel pick-up design works fine for this.
For the other .1%, they could redesign the fuel pick-up to a flop tube installation.
Scott McDaniels
Hubbard, Oregon
