Old 05-15-2017, 09:05 AM
DHeal DHeal is offline
Default Introduction of New-Style Carb Floats
FYI -- ROTAX has issued an SI describing their new-style replacement carb floats.
See: https://legacy.rotaxowner.com/si_tb_...si-912-029.pdf
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 650+ hours (as of July 2018)!
VAF donation through June 2019.
Old 05-15-2017, 02:27 PM
It appears that they shortened the length of the brass guide sleeve thus lightening the overall assembly which would make it more buoyant. What's another $200?
Hinckley, Ohio
PPL/ASEL 1970 Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 370
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 05-15-2017, 07:08 PM
catmandu's Avatar
catmandu catmandu is offline
Watched a pair of the new ones get installed last week, worked as advertised.
Mike C.
Maryland's Eastern Shore
stuck in 1/5th of an Arrow, my partners won't let me go
RV-6A bought flying
Old 05-15-2017, 07:19 PM
Pat Stewart Pat Stewart is offline
So have they corrected the material issue that over time allowed them to absorb fuel or just lightened them up.
Built, RV 8, RV8A, RV 10, RV12, Purchased RV7A
Restored J3Cub and PA28R180
Pecan Plantation
Eagles Nest Mentor
EAA Tech Counselor
Old 05-15-2017, 07:26 PM
Infidel's Avatar
Infidel Infidel is offline
It's not the first time Bing has changed the floats. Nonetheless, glad they stay on top of things.
RV-4 0320\D3G 160, Whirlwind 200GA 70".
Old 05-16-2017, 08:18 AM
rfchisholm rfchisholm is offline
Default New Engine
My brand new engine arrived from Van's a week ago. I will have to check to see if new floats were included, but I am going to assume that I have previous style. Looks like I'll be getting new-style floats while engine is still on bench. Is there going to be a market for unused older-style floats? Anyone interested?
Ronald F. Chisholm
RV-12; N439CH - Flying!
RV grinnin'!
2018 dues paid!
Old 05-16-2017, 08:41 AM
I sent you a PM. -- David
Old 05-16-2017, 08:46 AM
NOTE:
I read nothing in this Service Instruction that recommends or requires that all operators change to this new(est) style float.
For those new to the engine..... Rotax regularly issues service instructions that give details about design changes that have occurred.
Example - They issued one when the new style iS cyl heads were adopted for use on the carburated engine. That did not mean that everyone with a carburated engine was supposed to replace there cyl heads.
Scott McDaniels
Hubbard, Oregon
Old 05-16-2017, 08:55 AM
Jetguy's Avatar
Jetguy Jetguy is offline
My carb floats have over 900 hours on them.
John
RV12 N1212K
Flying Since June 2010
1020 Hours as of 9/30/2017
Johnrv12@icloud.com
RV14 Wing, arrived and building at Rdog's new Hanger at 16X
S/N 140014
Old 05-17-2017, 05:16 PM
Vantastic12 Vantastic12 is offline
Default New Rotax FLoats
A few weeks ago I had a needle stick on one carb. It pumped fuel overboard. Six hours on the motor. Fortunately, I was only taxiing. My motor's serial number is beyond the number affected by the 2015 Rotax Service bulletin. While cleaning the mid-range jet seat I had occasion to check the floats. The up-graded service bullet floats are identified by two small dots on one side of each float. One float had the two dots, the other had no dots.
I called Lockwood Aero and was advised that the some of the new two dot floats are also absorbing fuel and sinking. They had to return hundreds of them and now only stock the allegedly new floats, which are identified with three dots. I just ordered them for both carbs ($45.00 each times four) and received them two weeks ago--They are in fact identified with three dots. I installed same. Everything seems to be running well again. According to Lockwood, any float which weighs more than 2.9 grams is defective.
