Old 12-13-2016, 02:31 PM
olderthandirt olderthandirt is offline
Default Cold flying
Went up today, temp outside was 28 degrees...highest temp engine ever got to was 131 degrees...in the black on widget..flew for I/2 hour and decided it might not be good for engine to fly at this temp so aborted flight....question is was I correct in worrying with temp at 131...I can cover oil cooler but then always worry if temp outside goes up will it over heat??? Very...I mean very hard to start...
Retired Firefighter/Para-Medic
Sold 182 Skyelane
sold Super Cub
Building RV 12 E-LSA
Paid thru 2016, even though exempt
RV 12 completed, waiting DAR
Old 12-13-2016, 05:01 PM
JBPILOT JBPILOT is offline
Default Would advise for sure - -
You need some type of engine pre-heater. Starting a very cold 912 is a good way to ruin the sprag in the starter system. Very expensive to fix.
John Bender
Flying RV-12 - Serial #120036
Paid in May ( 5-4-18 )
Old 12-13-2016, 05:54 PM
Dvalcik's Avatar
Dvalcik Dvalcik is offline
I second the expensive comment since I just replaced one.
Mark aka "Skunkworks" had one of these and I got one. I am very happy with the heater. Low electric bill for the cold months in Maine
https://aerothermheaters.com/
Blow warm from the bottom and suck the return from the oil door.
David
EAA 1434 KBST
Belfast, ME
david@rv12pilot.com
2018 VAF Supporter
RV12 #568 EAB
* Started 9/30/2011
* 1st flight 8/30/12
http://www.rv12pilot.com
Old 12-14-2016, 01:35 AM
Gagarin737's Avatar
Gagarin737 Gagarin737 is offline
I have a thermostasis kit from Aircraft Specialty, covered the oil radiator 2,25" and have the "Bender baffle". Last week it was also around 28F in the Netherlands. Hangar was about 45F. Before startup I fully close the Bender Baffle. When I arrive at the holding point (2000ft taxi distance) the engine is around 120F. During flight I was able to maintain all temps around 210F. With the baffle almost closed I used approximately a quarter cabin heat otherwise it will be too hot in the flight deck.
PH-BZT
MyKitlog
Picasa pictures
Old 12-14-2016, 03:18 PM
Bevan Bevan is offline
Originally Posted by Mich48041 View Post
This is the RV-12 forum. 100W is never used in a Rotax engine. I use 10W-40 year around.
Sorry, I have deleted my post.
Bevan
RV7A Flying
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 12-14-2016, 08:43 PM
Aircraft Specialty Aircraft Specialty is offline
Good evening.
We specifically developed a Thermostasis install kit for the RV-12 which has proven to be popular in the colder weather climates. It significantly reduces engine warm up times as well as allows the oil temperature to remain much higher in flight and descent. No baffles are required. The complete kit includes hoses, fittings and the thermostat.
The hoses are all conductive Teflon fire sleeved hoses with an unlimited service life and a 10 year warranty.
If you have any questions, we are more than happy to discuss the installation. Please feel free to contact us or see our detailed install manual on the website.
They are built to order, and right now lead times run about 1-2 weeks.
This kit was released in late 2014 and we have had very good reports from those installing them.
Happy Building/Flying
Steve
Aircraft Specialty is Your Source for Custom CNC parts, CNC cut instrument panels and labeling, Teflon fuel/oil hoses, Headsets, and many other items for Experimental Aircraft.
aircraftspecialty@gmail.com
www.aircraftspecialty.com
Old 12-15-2016, 09:46 AM
Default pre heat
o.k. like Aircraft specialties thermostasis kit but still need engine warm so it will start...what is best pre heater for RV 12/rotax setup..thanks
Sold 182 Skyelane
sold Super Cub
Old 12-15-2016, 09:53 AM
Default Very pleased with - -
REIFF Pre-heat kit. I have mine plugged in all winter long. It is about 6 years old or more. Keeps entire engine about 90+ degrees if you cover engine with a cover of sorts. Was about $220 I think back then. Nothing against other more expensive kits, but just adds cost and complexity. Not hard to install REIFF.
John Bender
Old 12-15-2016, 10:12 AM
Phantom30's Avatar
Phantom30 Phantom30 is offline
David,
Where did you get your engine cowl plugs....looks good!
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 12-15-2016, 01:06 PM
Last year I used two hair dryers with short pieces of scat tubing shoved into the two cowl holes. I put a blanket over the cowling and a hunk of foam into to oval air inlet. At 30F ambient it took about 20 minutes for the EMS to show 70F on both oil and water temps. Worked pretty good.
That said, I'm saving up for a REIFF pre-heat kit which will have a safety timer turned on by remote cell phone switch. I plan on "calling" the plane a few hours before I drive out to the hanger and it will be warm when I get there. If I get weigh-layed the timer will shut off the heater for safety.
Hinckley, Ohio
PPL/ASEL 1970 Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 370
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
