Old 06-10-2016, 10:41 AM
Bill Palmer Bill Palmer is offline
Default Dual Everything
Dual Alternators (B&C 40-amp Alternator and SD-8-amp Dynamo); Dual Batteries (EarthX ETX680C's); all through an EFII Bus Manager here.
Bill Palmer
Old 06-10-2016, 11:11 AM
DanH's Avatar
DanH DanH is offline
I think it depends on the mission.
IFR? Dual batteries, dual alternators, dual regulators.
VFR? Big battery, schottky-fed small battery for second ignition, single alternator...KIS.
Dan Horton
RV-8 SS
Barrett IO-390
Old 06-10-2016, 11:36 AM
rcpaisley's Avatar
rcpaisley rcpaisley is offline
Default electrical system evolution
Dan's got it right,
Electrical system complexity follows a progression:
1. One batt, one alternator
2. Two batts, one alternator
3. Two batts, two alternators
One batt, two alternators is a problem. If you lose the batt, all you have left is half wave rectified AC power off the alternator - this means unhappy electronics. There needs to be a functioning battery in the system to absorb the pulses from the alternator.
Robert
EFII www.flyefii.com
Protek Performance
Old 06-10-2016, 12:36 PM
Carlos151's Avatar
Carlos151 Carlos151 is offline
60 amp main alternator, SD8 standby alternator on vacuum pad, one battery. Split Main bus and Emergency bus. Aeroelectric book has the setup in one of their diagrams. No time limit this way as with a battery.
Karl Richcreek
RV-8
N151TK "La Otra Chica"
Flying as of August 14, 2015
Old 06-10-2016, 01:37 PM
erich weaver's Avatar
erich weaver erich weaver is offline
Im not enough of an expert to argue with you here, but I consider Bob Knuckolls to be, and he would disagree with what you say above. I tend to respect his opinion.
erich
Old 06-10-2016, 02:34 PM
rcpaisley's Avatar
Default batts and alts
There really isn't anything to argue, that's how alternators work.
An important part of the evolving aircraft electronics systems is the evolving electrical distribution to support the new systems.
Robert
Protek Performance
Old 06-10-2016, 02:56 PM
Default Alternator Output
Hi Erich,
It’s Bob Nuckolls (spelling). Through Aeroelectric Connection and his various articles, Bob has contributed a tremendous amount to experimental aviation. I’m somewhat following Bob’s z14j architecture myself substituting an SD-8 for the auxiliary 20-amp alternator and inserting the EFII Bus Manager into that architecture. Bob is definitely one of our “good guys!”
That being said, just because Bob offers a schematic, that doesn’t mean that there might not be component issues associated with the schematic that you need to research and understand yourself. Yes, the electrons will keep flowing from the alternators if the battery fails, but, as Robert correctly mentions, the alternators in absence of a battery deliver a wave form that some electronics like avionics or ignitions may not like. Yes, most will keep operating, but possibly with signal (noise) problems or other issues. Components like lights or fuel pumps are usually not as sensitive.
I should mention that Robert Paisley is an Electrical Engineer (Cal Poly) and has decades of experience designing, producing, and testing fuel and ignition systems for motorcycles, cars, and, over the past decade, aircraft. He definitely knows what he is talking about and is one of our “good guys,” too. Rather than posting a “put down” here on VAF requiring a response or pitting one experimental aviation “good guy” against another, it might be best to call or send a PM or email first. Assuming that Bob would disagree with Robert is a real stretch and is probably not the case.
Robert’s (EFII’s) phone is 951-317-3473, you can PM him here on VAF via rcpaisley, and EFII’s email is info@flyefii.com.
I hope this helps,
Bill Palmer
Old 06-10-2016, 03:06 PM
krw5927 krw5927 is offline
Robert
All true, however can you please expand on "unhappy electronics"?
I've tested this very situation in my aircraft with dual alternators and a single battery. I took the battery offline by switching off the master contactor, to test whether the alternator(s) would continue providing power. The result was, if the main alternator field is already energized when the battery goes down, then it continues providing power. I even tried turning on and off various loads (pitot heat, landing lights, etc.) to test whether I could trick the alternator regulator (B&C) into going offline. Nope, still worked. Take the main alternator offline in addition to the battery failure however, and there's nothing left to energize the standby alternator field. (But now we're talking simultaneous, independent failures which is another debate altogether.)
Yes, you could hear the AC ripple noise through the intercom, but the electronics (full Skyview suite and Garmin IFR GPS navigator) kept happily humming along and sustained no temporary nor permanent damage.
edit: I do not have electronic ignition. Robert obviously knows more about his gear than anyone else, so if he says AC ripple is bad for his system then you can take that to the bank!
Kurt W.
RV9A
FLYING!!!
Old 06-10-2016, 03:57 PM
Walt's Avatar
Walt Walt is offline
I want to be able to continue a flight with no disruption and without alarming my wife if the main alt fails so I have a BC 20a backup with a single main battery. I also have a small EarthX for an avionics back up which can be crosstied to the main bus if needed. In addition I also added a couple of large capacitors on the main and avionics bus in case the battery relay fails there will still be some AC filtering to keep the avionics happy.
I would also have no hesitation about departing with only the backup alternator operating (VFR). There will be no side trips to Autozone or O'Reilly's for me.
My wife (like most) doesn't want any excitement in the cockpit, if the main alt failed she would have no idea it happened and I probably wouldn't tell her until we got to our destination
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Old 06-10-2016, 04:03 PM
rcpaisley's Avatar
Default robust electrical
There is always more than one way to solve any electrical requirement.
We use a very simple and robust scheme that doesn't include a master relay, or a typical aircraft right/left/both type switch. We also connect alternator outputs directly to batteries to avoid load dump. This is when an alternator gets separated from its battery and dumps its AC output through the rest of the systems.
Drawing 5A in our Bus Manager instructions (http://www.flyefii.com/media/Bus_Man...structions.pdf) shows how simple and robust, redundant electrical supply can be.
Robert
Protek Performance
