Old 07-09-2015, 11:22 AM
jmcanty3's Avatar
jmcanty3 jmcanty3 is offline
Question W-715 "Batwing" Tips
I have an older 2005 QB kit with the W-715 "batwing" wing tips. Other than aesthetics, is there any reason to change these out to the new W-715-1 tips? Any noticeable advantages in construction/ performance with the newest tip?
JC
John Canty
RV - 6 Purchased Flying (N542DP)
Old 07-10-2015, 04:19 PM
swisseagle's Avatar
swisseagle swisseagle is offline
Default Cut them of!
Hello John
I also got the "Bat-Tips", but during the build, Vans switched to straight trailing edge.
Due to the reason that the "Bat-Style" does only at the wings is and nor all over the other surfaces, I cut them straight, scuffed the inside very good and layed a few glas stripes inside with epoxy.
Dominik
RV-7A, TMX-IO-320, FM-150, Sensenich FP
Flying since 28. April 2016
Old 07-11-2015, 10:03 AM
Snowflake's Avatar
It's probably a personal thing. I've seen RV-4's retrofitted with the bat-wing tips and they look really, really good to me. As does a friend's -7 with the bat-wings. They're probably harder to make than the straight ones, so I understand why Van changed them.
Rob Prior
Old 07-11-2015, 10:49 AM
BillL BillL is offline
I have a much earlier kit and it also has the W715 tips. The functional difference in the tips is the light notch is one inch wider for the W715-1 with straight trailing edge. See page 79 of the Vans Catalogue.
This inch would limit options for tip-only taxi/landing lights. It may be moot anyway as the best LED's now only fit in the leading edge.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Old 07-13-2015, 07:54 AM
jmcanty3's Avatar
Default V speeds with various wingtips
Thanks for the feedback.
I like the way the bat wing looks too. Wondering if anyone has a pirep on handling qualities, V speeds (particularly stall speeds) etc. when comparing the various tips?
John Canty
Old 07-13-2015, 07:46 PM
carrollcw's Avatar
carrollcw carrollcw is offline
I have a newer kit that made its first flight in March. My DAR was surprised to hear that I didn't have any problems with a heavy wing, because most of the RV7's he had worked with had a heavy wing problem. He thought that I might not have had that problem since I didn't have the bat wing tips. Don't know if thats why mine flew so true right off the bat, but maybe something to consider.
RV-7 Flying Since March 2015
N412HC
Titan IOX-370
SDS Tunable Injectors
EFII Dual Ignition and Fuel Injection
Garmin G3X Touch
Whirl Wind 200RV Prop
7XS0 Polly Ranch Airpark, Friendswood, TX
Old 07-14-2015, 06:30 AM
Mel's Avatar
Mel Mel is offline
I changed from the original "hoerner" style tips to the "batwing" tips on my RV-6. I saw absolutely no change in performance. I was hopping that the small increase in span might lower the stall speed slightly, but no!
Actually, if anything, I believe the original tips were slightly more efficient.
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 07-14-2015, 07:43 PM
Bud K's Avatar
Bud K Bud K is offline
Like Bill L said, the 'bat wing' tips have a smaller area for the wing tip lights. I bought my -7 with the bat wing tips and wanted to upgrade landing lights. I have Whelen strobes and the current landing/taxi lights are partially blocked by the strobe lights. Can't do much with this configuration. Larger wing tip light openings would give me more options.
Bud K
N682TT RV-7
Legal Eagle (building)
FFR Roadster (sold)
Old 10-03-2017, 04:34 AM
WAM120RV WAM120RV is offline
Default Tip differences
Hi
Does anyone know whether there is any difference to the tip leading edge profile. Is it possible to modify the old style tip to accept the larger LL7-8MR16 wing light kit.
http://www.aerobuilder.blogspot.com
Steve Arnold
England
In completion stage of Loehle P5151
Built and now Flying G.BVLR Vans RV4
Rebuilt G.BDBD Tailwind
Rebuilt G BVTN Kitfox
Built G CDCD RV9A with WAM120
Riveted wings on Glastar G.LEZZ Now (G. SKUA)
Old 10-03-2017, 06:26 AM
Default No change.
We have them and they are the same other than the bigger pocket for the landing lights in the newer type. We put the RV- style landing lights in the smaller pocket and it work well that way with them and "L.E.D." bulbs installed to replace the Holide RV-10 bulbs. There are a couple of kit out there that have bigger cut-outs and bigger "L.E.D.s" you can install in the tips, both old and new style. It is just what you like to have in those cases.
Hope this helps. Yours, R.E.A. III #80888
