Old 04-03-2015, 10:13 PM
Mike D's Avatar
Mike D Mike D is offline
Default Why an overhead console?
So, why an overhead console?
Seems everyone does it. But what do you actually use it for other than lights and air vent hose?
Michael Delpier
RV6A -O-320, fixed pitch, GRT Sport, 496
RV-10 - working on finish kit
Houston
Old 04-03-2015, 10:41 PM
N427EF N427EF is offline
Default You said it
Lights and most importantly fresh overhead air supply.
It also makes a convenient cover for wire bundles for GPS antennae
or headset wiring.
If you live in a hot climate the overhead fresh air supply is enough reason to add an overhead console IMHO.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 400 plus hours
Over 2500 Gallons of E10 mogas burned
Don't believe everything you know.
Old 04-03-2015, 11:23 PM
bpattonsoa bpattonsoa is offline
I agree with Ernst, but they reduce headroom. I am 6'4" and very long in the upper torso. I Bumped my headset when leaning to the center. Actually lowered the seat 1" to get enough headroom.
I know about the carefully designed seat foam, but if you can't be comfortable, why build a -10? My -6A had a 3/4" seat cushion before I did the Almost A -14 Aerosplat mod.
If you are tall or long upper body, try to find one to sit in before you drop the money on the overhead.
Bruce Patton
Building Rans S-20 Raven 796S reserved
Going to the light side!
RV-6A 596S flying since '99 (Sold)
HP-18 5596S flying since '89
RV-10 996S tail, quick build wing and slow build fues., - dual Skyviews with complete system, two radio and not much else. Interior completely finished with Zolatone. CF plenum, interior complete. 1624 lbs, FLYING after a 21.5 month build.
Old 04-04-2015, 12:30 AM
Seems everyone does it. ?
Well, not everyone! Build what you want.
Old 04-04-2015, 05:04 AM
rleffler's Avatar
rleffler rleffler is offline
It was the only mod that my wife insisted I install. She wanted fresh air blowing in her face an not her crotch. Now that I'm flying, I think air in the face is more effective at being perceived to cool you off than the standard vents.
I have the Aerosport Products console installed and have not found it to be an issue of hitting my head on the console.
Secondarily, I'm got all of my interior lighting installed in the console as well.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 04-04-2015, 06:14 AM
Mike D's Avatar
Good replys so far. Thanks!!
How are most getting the fresh air to the front and rear seats?
Are you adding NACA vents in the rear and using scat tubes to pull it forward? Is there another way?
Do others without the overhead vents feel you need more fresh air?
Michael Delpier
Houston
Old 04-04-2015, 06:37 AM
Auburntsts's Avatar
Auburntsts Auburntsts is online now
You have to add NACA vents in the rear. I opted to go with one on the right side, which feeds 4 eyeball vents the overhead. Some have opted to go with 2 NACA vents (1 on each side). SCAT connects the NACA to the overhead.
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 04-04-2015, 07:20 AM
1001001's Avatar
1001001 1001001 is offline
My Warrior has a ventilation fan in the tail cone that allows forced air distribution through the overhead vents while on the ground. There is a pickup at the top of the vertical stab that connects to the fan suction with scat tubing. The fan then feeds into the overhead console.
Has anyone considered a similar arrangement for their -10? The extra ventilation due to the fan is great on hot days on the ramp. You can direct a stream of air right on top of your head, which helps a lot. It may not be as good as air conditioning, but it is pretty useful.
Old 04-04-2015, 07:49 AM
Gary 40274 Gary 40274 is offline
Default Do it your way
There have been so many 10s built with many variations that when you ask about any option lots of folks who have chosen that particular option jump in the forum to convince you to also do that option. Those that chose a different way remain silent so you never get a sense of how the masses are going.
It would be my unscientific sense that there are more 10s without the overhead console than with it. I do not have it and am perfectly happy without it. Also saves lots of time and money
Gary
Old 04-04-2015, 08:00 AM
9GT's Avatar
9GT 9GT is offline
I only have lights and dimmer controls in my overhead console and it hides my antenna coax cables. I built my own and made it only 5" wide and 3/4 " deep in the front. I did not want anything wider than the 5" because I wanted to maintain headroom in the seating areas. I have found that if I open the front NACA supplied eyeball vents on the ground, I get a very good airflow through them as soon as I fire up the engine as the NACA's collect air from the prop blast.
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2018
