Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 01-20-2015, 09:11 PM
petersb petersb is offline
Default Where to get Hartzell prop paint ?
Need to TouchUp Hartzell CS prop.
I likeTemp Hartzell prop paint, however it is grey, my prop is a light silver.
Any thoughts
RV7A New Dec 2013 - 360, C/S, slider
RV6 - 1600 Hours ---- Sold
Old 01-20-2015, 09:29 PM
RV6_flyer's Avatar
Default Flat Black
I have only touched up the Flat Black with purchased spray paint from VAF advertiser Aircraft Spruce. They list 3 different colors. I do know of one friend that did gray and white touch up on a Hartzell years ago and I was not able to tell that there was any change in color.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Building RV-8 S/N: 80012
Old 02-20-2017, 03:56 PM
dweyant dweyant is offline
Does anyone know if the Aircraft Spruce grey paint.
http://www.aircraftspruce.com/catalo...lickkey=280346
matches the Hartzell propellors? I need to touch up a couple small spots on my prop.
And is there a better option for a couple small nicks? After I have them dressed I'd like to put some paint on them.
-Dan
Dan Weyant
RV-9A N96KD
Done and Flying 4/30/2015
Old 02-21-2017, 11:03 PM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
Table 6-12 in my Hartzell owner's manual has a table that lists Tempo and Sherwin-Williams colors and part numbers for all the colors.
ETA: ACS has the black, white and grey Tempo spray paints for Hartzell props:
http://www.aircraftspruce.com/catalo...?clickkey=9130
Old 03-02-2017, 12:26 PM
MikeyDale's Avatar
MikeyDale MikeyDale is offline
Well, I have dressed a few nicks in my Hartzell blended airfoil prop I purchased new 3 years ago. I bought the Tempo A-151 Med Gray Epoxy Coating, P/N 09-00983 from ACS and it definitely does not match my original silver! Has anyone found the right product that will match?
Mike Hillger
RV 7 FLYING SINCE 4/2015!
Garden City, Texas
First Flight https://www.youtube.com/watch?v=QqgxhWH3pqA
Build Blog http://mikesrv7.blogspot.com/
Dues Paid
Old 03-05-2017, 01:54 PM
pilotkms pilotkms is offline
Default Safety wire?
Cant for the life of me find POST NEW THREAD button so tagged on to this Hartzell thread with REPLY.
what are the tricks to putting safety wire thru the 6 large bolts with the roll pins?
Thanx
Keith
Keith
RV 7A. RV #9700
Built in SoCal KCCB
N325KS
Phase 1 Completed Nov 2017
Old 03-05-2017, 05:05 PM
Thanx
Keith
At the very bottom of the page is a 'Forum jump' page. Select one e.g., PROPS. Now at the top of the new (PROPS) page is a 'new post' button.
I don't recall any tricks to safety wiring the prop bolts other than a lot of cussing.
Old 03-05-2017, 10:29 PM
Thanx for New Thread directions Bob. I had not used that before.
For the next guy > smooth both ends of the safety wire on a 3M wheel.
Put wire thru pin and push the point after it goes thru with a screw driver.
Grab end with needle nose pliers and pull it to start direction.
Push in 1/8" increments while gently pulling from other side.
Verify correct direction - I also used a few unprintables.
Got it done in about an hour. Shorter next time.
Keith
RV 7A. RV #9700
Built in SoCal KCCB
N325KS
Old 03-08-2017, 05:21 PM
mike newall's Avatar
Glad this thread resurfaced.
What is the RAL code or BS code for Hartzell Gray.
Need to get some mixed.
Not looking for product, just the code to mix the paint as I want to use it as an interior color.
Donated twice in 2017
Old 03-08-2017, 06:02 PM
Larco Larco is offline
Thanx
Keith
As said by others a real PITA but many of us will torque the bolts then if needed loosen the bolts one at a time to put wire through then retorque the bolt then onto the next one. Hard to explain but a lot of patience is required. :-)
