Old 09-08-2017, 08:05 PM
rsipp rsipp is offline
Default Main gear leg & intersection fairings
For those of you that used RV Bits main gear intersection fairings from Cleveland, along with the main gear fairings which gear leg fairing did you use? The instructions specify "main gear rod";
I tried the "RV8 main gear" based on other information and was not able to make them fit; they seem to not have enough cord dimension.
If you used the "rod" as specified did they fit OK?
Dick Sipp
Old 09-08-2017, 09:27 PM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
I have done two planes with that option. You do have to remove tiewraps on the main gear legs in order for them to fit, and they do fit very snug. I used a hinge on the rear edge, with an ability to pull the pin for removal.
I think on the last order I determined that the leg fairings were used on more than one RV.
Retired US Army Officer
Old 09-08-2017, 10:35 PM
rongawer's Avatar
rongawer rongawer is offline
I bought the 'GEAR LEG FAIRING ROD" set. Although I have not yet completed the intersection fairing installation, I did fit everything up and the leg fairings I bought fit fine. They do get shortened up though.
Ron Gawer
- RV10, N1530G (reserved). Empennage in progress.
- RV12, N975G, Flying
Old 09-10-2017, 07:01 PM
Thanks guys appreciate the advice.
Old 10-12-2017, 03:41 PM
Default Fuselage to Gear Leg Fairings
I installed fuselage to gear leg fairings today. $79.98 from Texas Areoplastics @ BuyPlanParts.com. BPP allowed me to buy only the upper fairings out of a complete set of four. I donít want to install intersection fairings at the wheel pants.
Installation was simple using Rivnut for 6-32 truss head screws. 1/32Ē rubber edge trim HR69C was sourced from eBay.
Hinckley, Ohio
EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 392
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 10-12-2017, 04:59 PM
funflying funflying is offline
Looks good Jim. Thanks for the update and resource information.
Patrick Claar
Arvada, CO BJC
RV12, #401, Flying 2013, N612PC
RV6, 1996-2010 sold
Old 10-13-2017, 08:10 AM
Rrhsch Rrhsch is offline
Jim,
What holds the rivet nut in place and from spinning?
Old 10-13-2017, 08:25 AM
The Rivnut is installed with a special tool that forms an upset ring on the back side. See pic of test sample I did before actual installation on the plane.
Hinckley, Ohio
EAA #499867
Old 10-13-2017, 10:47 AM
DHeal DHeal is offline
Typically the rivnut has a small tang under its head that indexes into a matching slot filed into the base hole. This serves to keep the rivnut from turning. With a bit of finagling, you may be able to modify a screw and standard pop-rivet puller for use in setting rivnuts -- this may save you from having to buy a special rivnut tool.
ps -- We're still here in Santa Rosa but some of our local RV builder/owners have lost their homes and shops to the fire. Bad scene.
EAA #23982 - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 670+ hours (as of Sept 2018)!
VAF donation through June 2019.
Old 10-13-2017, 11:01 AM
You can buy the tool at Harbor Freight, but be sure to use Aircraft grade rivnuts. The ones that come with the HF tool are junk.
