Old 03-12-2017, 12:54 PM
Jpm757 Jpm757 is offline
AFS Quick Panel fired up for the first time. Can't wait to get this this thing in the air!
Jake Mahoney
RV6 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017
2018 dues paid.
Old 03-14-2017, 11:55 AM
Md11av8r Md11av8r is offline
Almost ready!!
N900EC RV7 IO360, Dual Dynon HDX, IFD 440, SL30, AP Control Panel, Knob Panel, ADSB IN/OUT
Old 08-23-2017, 12:01 PM
KatanaPilot KatanaPilot is offline
Default New panel from Stein
Here is our RV-7A panel on the bench at Stein this morning. Can't say enough good about the support and expertise from Stein and his team.
Only known change will be to lever-lock switches for the ignition.
https://www.dropbox.com/s/96v59k8j3i...panel.jpg?dl=0
Krea Ellis
Locust Grove, GA and Miramar Beach, FL
DA20-A1 Katana "Princess Amelia"
RV-7A under construction
RV-10 under construction
Old 09-22-2017, 05:08 PM
Rbb469 Rbb469 is offline
Very nice panel!!!!
Paid 5/2017
Old 10-08-2017, 05:40 PM
sahrens's Avatar
sahrens sahrens is offline
Default My panel completed
I tried to keep it clean and simple.
Working with Bill at UpNorth Aviation I completed the design work and he cut the panel. The labels were done by Matt at Aircraft Engravers. Stein built the wiring harness for the radios including the headset jacks. All three were wonderful to work with and made the panel process very easy.
Scott Ahrens
RV-7 N818BG
Test flight in progress
Old 10-23-2017, 09:41 PM
bret's Avatar
bret bret is offline
Default Dynon stuff
2018 gladly supported
Old 10-24-2017, 06:13 AM
Simon Hitchen Simon Hitchen is offline
Default Ace
That does look very sharp Bret.. nicely done!
One of the best I've seen
Simon Hitchen
Port Perry, ON, Canada
7 Tip Up, Titan XIO-360, Sensenich FP Prop, Dynon Skyview, GTR-200, GTX-327
FLYING!
Old 10-24-2017, 10:26 AM
bret's Avatar
Thanks, just acquired the second panel from a nice gentleman here on the forums, little did I know....that when I plugged in the second panel, there was some kind of conflict, I lost everything as far as set up, it took several hours to redo all my fuel tables and re set everything, should have saved my settings before adding the second screen, live and learn, but its all good now.
Old 10-24-2017, 12:38 PM
Raymo's Avatar
Raymo Raymo is offline
Bret,
This thread on the Dynon site would have saved you the headache.
http://dynonavionics.com/cgi-bin/yab...1508099236/1#1
"New displays are basically primed (using that special DYNON tail number) to adopt/copy in all of the settings when you do a network configuration from an existing display."
Beautiful panel, BTW!
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 10-24-2017, 02:15 PM
bret's Avatar
Thanks for that info, but Just to save someone from making my mistake, I bought this kinda used, it was in very new condition but had the previous owners tail number set and I did not notice this until it booted up, then red Xs started popping up everywhere.....NOOOO, in any case, it was a good exercise on how to configure a complete Dynon system.....again, luckily I had all the fuel tank sensors cal numbers and EMS pinout notes
