Old 09-30-2017, 02:39 PM
Adam W Adam W is offline
Default 661 EF flap actuator end block question
after installing the actuator and bolting in the blocks the movement is smooth but feels slightly restricted. examining my installed end blocks (661EF) it looks as thoiught the section against the 705 is not perpendiclar to the face of the block. maybe a few degrees out by eye. my question is are these blocks "left or Right"? can they be installed on the wrong sides?
Adam Wachtel
Thornhill Ontario Canada
Building RV7 #70770
Wings done
Empenage done
QB Fuse done
Finish kit underway
Vans Airforce Dues Paid
Flying Piper Supercub PA18 150
Flying Cessna 414A
Old 09-30-2017, 02:57 PM
az_gila's Avatar
az_gila az_gila is online now
Exclamation
Same part as the -6s and those plans give precise manufacturing dimensions.
They are not L and R and the tube recess is shown as square to the surface of the block.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-30-2017, 05:12 PM
If you are able to move it by hand with out major effort, the amount of friction it has will not be a problem.
Scott McDaniels
Hubbard, Oregon
Old 10-01-2017, 07:21 AM
wirejock's Avatar
wirejock wirejock is offline
Default Blocks
Scott as always.
Mine were the same. I fought with them quite a while a d got them a little better but in the end it didn't matter. The flap motor has no problem with it. In fact, make sure everything is correct. I suspect that little motor can do damage if something isn't right.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
