Old 05-21-2020, 05:09 PM
Beech350guy Beech350guy is offline
Originally Posted by kbalch View Post
I've been motoring along pretty well and making good progress nearly every day. One task today, however, has seen me talking to myself out in the garage as I tried to figure it out.
On page 09-18 Step 5, how the heck is one meant to buck those rivets along the rear spar?!? I have the special bucking bar, but that's intended to utilize leverage (when doing the second skin) unavailable with the assembly clamped to the edge of the workbench for this step per the plans. None of my many other bucking bars fit suitably inside the rear spar. Is it a two-person job with the special bar? It'll take two hands on that bar and I'm short a third hand to run the rivet gun...
What am I missing?
I just arrived on page 9-20, figure 1 where that special bucking bar comes in. I have the special bucking bar, but that looks like a wonderful way to screw up my elevator. The blurb above the callouts for the special bucking bar indicates that an MK-319-BS is acceptable for solid rivets anywhere this bucking bar is to be used.
My question: Has anyone else tried using Cherry's in the rear elevator spar? In the hinge portion of the left rear spar, I actually riveted it vertically, as the thought of driving down into the spar directly gave me pause.
I am leaning towards using Cherry's rather that the MK-319-BS's.
I welcome feedback from the group. THanks!
RV14 Empennage kit arrived June 2019.
H-Stab done.
https://n820mm.blogspot.com/
2019 Dues Paid
Old 05-21-2020, 05:24 PM
kreidljj kreidljj is offline
Default It is simple with the special backing bar
The special bucking bar makes quick work of the rear spar rivets. You need to let part of the bar hang off the edge of the table. You push down on the portion of the bar hanging off the table, the bar pivots on the edge of the table, then shoot the rivet. I clamped the part to the table so it didnít move around. I donít know how you would get in there with the tungsten bar (I have one and use it Ďalwaysí), but in this case the special bar is the way to go. - Jason
Old 05-23-2020, 09:18 AM
R&J Cosh R&J Cosh is offline
Jason is absolutely correct. The special bucking bar works great.
Old 05-23-2020, 10:55 AM
Ralph Inkster Ralph Inkster is offline
My tool box contains various old bodyman's hammer heads, various smoothed off chunks of bar stock, a old railroad spike, bars drilled to accept various squeezer sets, whatever works. Sometimes necessity requires creativity. Oh, I have a whole collection of usual Tungsten & steel Bucks too.
Ralph
It's time to work on just my own planes, not everybody else's...
Old 05-23-2020, 11:46 AM
rvbuilder2002's Avatar
Ralph is correct. That is the exact reason that the special bucking bar was designed.
The first prototype elevator was built using a 1/4 “ thick piece of steel plate about 3 “ wide by 18” long. It worked but not as well, and it required careful planning of the riveting sequence to avoid interference from previously installed rivets.
The custom bucking bar makes it easy because it focuses a lot of bar mass on the rivet which is important since you have to fulcrum the bar to hold it against the rivet. This excess mass makes the rivets set very easily.
Opinions, information and comments are my own unless stated otherwise. They do not necessarily represent the direction/opinions of my employer.
Scott McDaniels
Van's Aircraft Engineering Prototype Shop Manager
Hubbard, Oregon
Old 05-23-2020, 11:55 AM
HAL Pilot's Avatar
HAL Pilot HAL Pilot is offline
One option is to use a bar shaped bucking bar or the rv14 Special bucking bar create a fulcrum under the bar and place the end of the bar on the shop head with the rivet gun driving the bar.
I created some diagrams on my "wiki" plans page just after the page in question. See my signature line.
Pete
RV14A Tail kit build mostly done
Wing kit in progress
RV 14 WIKI in process, residing on Drop Box
https://www.dropbox.com/sh/xu5p6f4l7...bU0ck0pJa?dl=0
change dot org link http://chng.it/KBPtXZYD
---For Edit Access drop me a PM with your Email address.
EAA 1300
Donation Paid 2018, 2019 Military exempt but paid any way Cause its worth it.
