My engine mount has a small touch of surface rust on it which I've used a wire brush to clean off.
I bought some rustoleum primer to re-cover the affected areas but I noticed it says "don't use in areas that get hotter than 200f". Oops, I guess that gets returned.
I noticed they have a "High Heat Enamel, Barbeque Black" type. Is that ok to use? Is there a better protectant for touching up engine mount paint?
