  #1741
Old 05-17-2017, 08:55 PM
gottawork gottawork is offline
Very nice! I admire those of you that can use are skilled with a paint gun.
RV6 IO360-A1A
Airspeed: Speed of an airplane. Deduct 25% when listening to a Navy pilot.
Old 05-18-2017, 11:19 AM
dave4754 dave4754 is offline
Default Lookin Good!
I have thought to do the same thing as you in that i want to paint it all at home and then transport to airport for final assembly.
Love to hear how the trip goes. i feel that even if a few scars need fixing it will be easier to paint (and cheaper) at home where all the tools are and you dont need to rent hangar space.
She really looks nice. Great job
Any advice on how to get my cowling on like yours would be greatly appreciated LOL the thing has it in for me...
Dave Cobb
=VAF=2017 Donation - and a bit extra for great work!
Empennage RV 7 - Tipper
Wings complere
Fuse coming along, Canopy looking good!
AME reviewed and repaired O-320-Lyc installed
Old 05-18-2017, 05:56 PM
Simon Hitchen Simon Hitchen is offline
Default Thank you Dan Horton
The painting has been interesting for sure. Love the end result but boy what a lot of work. I went base/clear knowing that i could follow Dan's advice on color sanding and buffing. Worked like a charm!
This is the cowl after clear coating. It looked pretty good.
Then I cut it with 1000, 1500 and 2000 grit paper so it looked like this
Then I used the Norton liquid ice system and got it to look like this.
So thanks for the inspiration Dan. I've enjoyed painting at home and especially the convenience of doing it in bits.
Simon Hitchen
Port Perry, ON, Canada
7 Tip Up, Titan XIO-360, Sensenich FP Prop, Dynon Skyview, GTR-200, GTX-327
FLYING!
Old 05-18-2017, 06:11 PM
Default Cowl
Thanks Dave, I'd encourage anyone to try and paint it at home. Yes I've damaged a few bits here and there but I've learned how to repair painted parts and blend them in which is nice to be able to do.
As for the cowl it's really been a case of just trial and error. The two halves didn't fit too well so I cut off the front flange got tgem to fit perfectly and reglassed in a strong flange that fit perfectly. Lots of epoxy with lightweight fill, glass and a few epoxy skim costs to fill the weave and pin holes I must have sanded those darn cowl at least 10 times...
If I can be of help Pm me and we'll talk.
Simon Hitchen
FLYING!
Old 05-19-2017, 05:01 PM
bret's Avatar
bret bret is offline
That looks real nice! how many coats of clear, and did you break through to the base coat anywhere? I did B/CC also but a little skittish to sand on it, did that once on a car and broke through a couple of places with the buffer.......is there any ridge at the color changes, that's where my fear is....
2018 gladly supported
Old 05-19-2017, 07:39 PM
Default Clear
Hey Bret,
I put one good coat of clear on the airframe but two coats on the cowling because I think it'll get a little abused. Not many problems burning through the clear but I used a very soft foam sanding block and foam pads with the buffing wheel. The few times that I did manage to burn through on edges and a few high rivets I just got out the airbrush, recoated just that area, let it dry then blended it in with light sanding and buffing. No trace visible.
It really is worth while doing it if you can. Take a deep breath and go for it. My wife couldn't believe I was going scuff it all up...but now she's glad I did.
Best of luck
Simon
Simon Hitchen
FLYING!
Old 05-30-2017, 01:59 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Default Engine progress...
So while out in the sticks in the land RV my engine builder sends me these teaser pics for the RV7 project. Fantastic weekend closing booster!
IO-360-M1B
Carlos in Arizona
EAA Chapter 538 President, www.538.eaachapter.org
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 05-30-2017, 05:57 PM
wirejock's Avatar
wirejock wirejock is offline
Default Congratulations
Congratulations. Sweet!
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 05-30-2017, 06:20 PM
DanH's Avatar
DanH DanH is offline
Simon, it looks great, and you're quite welcome. Really, I get a lot of pleasure in seeing someone do so well.
Dan Horton
RV-8 SS
Barrett IO-390
Old 06-12-2017, 08:03 AM
BoilermakerRV's Avatar
BoilermakerRV BoilermakerRV is offline
Default Rolled the Canoe
Rolled the canoe this past weekend. I think this is the first time that I have truly believed that I can finish this project. It just seems more real today compared to the ambiguous "someday" that it has been for the past several years. Very motivating.
Michael
Danville, IN
RV-7A Fuselage
N317PU Reserved
2017 Dues paid (July 2017)
