Hey folks,
I would like to get feedback on expected performance for a 3-blade prop and any recommendations on moving to a larger blade diameter. The situation is I originally ordered a 72-inch 2-blade Aerocomposites prop, and due to a number of issues, ended up with a 3-blade 68-inch prop. I'm turning the prop with a TMX-O-360 Red-Gold, RV-7, tip-up;
At 75% cruise, the best I can do is about 184 MPH TAS, 65%, 177 MPH TAS, WOT, maximum speed is 197MPH. Airplane is flying straight, balanced, etc..
A few questions:
Are these cruise speeds in the ball park?
Can I push a larger diameter 3-blade prop, say 72 inches with 180HP?
Reason for asking is we were expecting to loose 2 or 3 knots with the AC 3-blade prop, versus 2-blades, from the book numbers, but, we're down 10-15 knots (or so it appears). In a side-by-side comparison with an RV7A, I need to run about 2 inches of MP higher to obtain the same speeds, until I run out of throttle.
The disconcerting aspect is the AC propellor is NOT custom designed for the 68-inch, as I understand it, they start out with a 78-inch prop, and simply lop off the tips to get the desired diameter. I have about a four inch wide prop tip, looks like the end of a canoe paddle.
I have not been successful in obtaining a 2-blade prop from ACI up to this point in time, it has been nearly a year of lobbying.
A few questions:
