Pitot tube hole
Future RV 9 Flyer
Ready to install left top wing skins but was wondering about pitot tube hole.am going with aoa but not sure what mast to use. Does it matter what brand panel you go with as I most likely will have glass?all suggestions welcome.thanks
Many use the Gretz pitot mount.
AOA is built into the Garmin and Dynon pitot tubes. AFS AOA uses holes in the top and bottom of the wing. These can be drilled at anytime.
Your choice of EFIS may have an impact on your choice of pitot.
The good news is that you have plenty of choices.
AFS's post-Dynon rev of the 5000 series can use either the Dynon pitot-AOA or their original wing port version.
