Old 08-19-2019, 03:34 PM
bjdecker's Avatar
bjdecker bjdecker is offline
Default The mystery of #4...
Greetings,
I have a bit of a mystery and would like to appeal to the brain-trust for assistance.
The configuration: RV-7, Lycoming YIO-360-A1B6, Hartzell F7497 CS Prop, Dual Lightspeed Plasma III - timed to 20°, Denso IK27 plugs, Avstar AVX-5VA1 fuel injection servo, Standard pistons (8.7:1 CR), Custom Plenum, SW 8406R oil cooler mounted on firewall fed by 3" SCEET duct from above #4 cylinder, Temperature risers are installed in front of #1 and #2 cylinders - #1 is 1/4" lower than "stock", #2 is 3/4" lower than "stock", #2 cylinder is the hottest - followed by #3, #1 and ultimately #4.
The symptom: during climb out, and in all subsequent phases of operation at or above 80 Kias, the #4 cylinder will run ~30° colder than the other 3 cylinders (#4 max is 336°F, others max ~365°F).
Additional data: all 4 cylinders "peak" within .1GPH (e.g. 9.3GPH at 6500msl), and all EGTs are within 75°F of each other for all phases of flight. Probes have been swapped, tested, and appear correct.
My objective is to get #4 up to the same temps as the rest. Any ideas would be greatly appreciated.
B
Brian Decker
Retired Firmware Guy and Airplane Builder
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned
1998 RV-8 QB -- Started, Sold
Aided and abetted building a number of other RV's.
Old 08-19-2019, 05:24 PM
JohnInReno's Avatar
JohnInReno JohnInReno is offline
Default Check this
http://www.vansairforce.com/communit...ghlight=baffle
John Morgensen
RV-9A N946PM 600+ hours since 2013
Nevada/Arizona
Old 08-19-2019, 06:43 PM
bjdecker's Avatar
Default Check this -- not that...
Originally Posted by JohnInReno View Post
Hey John -- thanks for the reply; unfortunately - nothing in the attached thread was applicable; K-type probes and K-type configs, #2 and #3 gaps are ok, problem is with #4 getting too cold, not the others running too hot...
I wonder if the temp riser in front of #1 is too high and there is a cross-flow behavior that's pushing more air to #4 as a result? #1 sits in front of #2 laterally, and #1 catches the air spilling off the trailing edge of the prop moving DOWN -vs- #2 which catches the air spilling off the trailing edge of the prop moving UP...
B
Brian Decker
Old 08-19-2019, 08:48 PM
RV8Squaz's Avatar
RV8Squaz RV8Squaz is offline
Originally Posted by bjdecker View Post
Greetings,
B
Sounds like you have the same numbers I’ve had on my IO-360A1A powered RV-8 for the last 12 years and 1700 hours. Those numbers are identical to my friends’ RV-8’s with the same engine. Many years ago, I trimmed the dam in front of #2 with no appreciable change. That cylinder just runs cooler than the rest. Think of the cooler temp on #4 as a bonus and enjoy.
Jerry Esquenazi
RV-8 N84JE
Old 08-19-2019, 09:33 PM
sjhurlbut sjhurlbut is online now
Default UP?
Bring CHT up? Why? Temps are looking good. Think of CHT and cylinder peak pressure instead. You never want to increase it.
Visit and subscribe to Stu's Aircraft Factory on YouTube!
Donated even though exempt
Steve "Stu" H
Cold Lake, Alberta
RV7A #70015 - C-FZQX - built - sold
RV7A #71629 - C-FSIS - built - sold across Atlantic
RV7 #70215 - C-GOJU - flying - sold
RV7 #70703 - C-GMIY - flying - sold
RV6 #60119 - C-FHBZ - built - Airventure 2016 Bronze Lindy - sold
RV10 #41779 - built emp - sold
RV8 #82842 - C-FSBG - Fastback with big hp IO-360-A1B6 10:1 - built - flying
Old 08-20-2019, 08:30 AM
Snowflake's Avatar
I agree with Steve. Try to bring the other three cylinders *down*, not #4 up.
Rob Prior
Old 08-20-2019, 02:38 PM
scsmith scsmith is online now
Me too. #4 runs coolest by 30F. For me, it is more like 265F when the others are in the 290--300 range.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 600
also LS-6-15/18 sailplane
VAF donation Jan 2020
Old 08-20-2019, 04:39 PM
bjdecker's Avatar
Thanks for the data Steve(s), Rob, Jerry. I was beginning to wonder if it was something that I had done.
I guess I'll just enjoy the temps
Brian Decker
