Old 08-09-2019, 06:01 AM
mulde35d's Avatar
mulde35d mulde35d is offline
Default Lighted Switches
So while sitting with my wings complete and awaiting the arrival of the fuselage I took the time to photograph some back lighting options for AML34 Switches that fit nicely under Garmin GDU46X panels in the RV-14. These AML54 rockers from engravers.net are shown in AML34EBA4AA01 switches with LE-0504-01 LED Lights from digi-key.
These are all the same Switch and Rocker, just with different LED lights installed (really easy to change out). From left to right is Blue, White, Yellow, Green, Red. Of note, the Green is really bright and the blue is not far behind. I am doing some additional experimenting with filling the transluscent engraving with white paint to make it more readable when the light is turned off. Will post more info on that later.
Thanks again to the guys at engravers.net for sending me some sample rocker switches to play with.
Jon
http://www.mykitlog.com/mulde35d
RV-14A Sold
RV-10 Research In Progress
Old 08-09-2019, 07:42 AM
Walt's Avatar
Walt Walt is offline
As Stein would say just my 2c
Pro's:
Look "fancy"
Con's:
Cost more
Quality/reliability not as good as Honeywell toggle
Quick connect push on connectors not as robust/secure as screws
More complex to install with wiring and dimmers
Take up more room
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 08-09-2019, 09:41 AM
Bavafa Bavafa is offline
Pro's:
Look "fancy"
Con's:
Cost more
Take up more room
Plus 1, if I may.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 08-09-2019, 02:26 PM
mulde35d's Avatar
Default Fair
Fair opinion. I would argue pros also include
Ease of switch identification in low light
Reduced risk of leaving components on when they shouldnít be (Pitot Heat, Autopilot Inhibit, etc)
Not that anyone ever leaves pitot heat turned on after landing, right. I plan to make that one yellow or red.
I do agree in some cases upper face switch dependent lights donít make sense because the normal position is ON such as the master, alternator, and avionics. In these cases it isnít really notifying you of anything that you shouldnít already be aware of based on your screens being powered.
I find the additional light indicating operation helpful for things such as pitot heat, landing light, navigation lights, autopilot inhibit, ESP-X activation, etc. just differing opinions which is why I love experimental aviation. Everyone gets to have it their way.
Jon
RV-14A Sold
Old 08-09-2019, 02:35 PM
Av8rRob's Avatar
Av8rRob Av8rRob is online now
Well, I think they look awesome!!!
Rob Lasater
Rv-14 still workin, but getting close
Paid Dec 2019
Old 08-10-2019, 10:29 PM
dmattmul dmattmul is offline
Default Thatís why we build
We build experimental airframes so we can choose what we want. As long as itís safe and functional, builders choice. VAF needs to limit naysayers, whatís the point to dissing others personal options?
Thanks for sharing the color options, I applaud the effort and might need.
Seems easier to criticize than create.
RV-14A QB building, Lycoming 390 Thunderbolt arrived July 2019, Garmin avionics, Vertical Power, EFII-32 Ignition and Fuel, Whirlwind 300-72, hope to be flying Summer of 2020 !! Dues paid+ of course !!
Old 08-10-2019, 10:38 PM
Default Cool Idea
I actually like the idea of illuminated switches. Thanks for sharing, I will look into them.
John S
Dues paid 2020, worth every penny
Fuselage 50%
Old 08-10-2019, 10:42 PM
Default Colors for IFR
So for the experts on IFR lighting, what colors are best for an IFR panel? I was taught green or yellow, but my IFR ground school said to use white when on final and dont worry about preserving night vision because proper color rendering was more important.
What are everyone’s thoughts on color for IFR?
John S
Fuselage 50%
Old 08-11-2019, 05:49 AM
Default Data point
At work, pretty everything is white light with the exception of a red lense on the grimes light...that never gets used...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 08-11-2019, 06:12 AM
mulde35d's Avatar
Default IFR vs night
What are everyoneís thoughts on color for IFR?
I hadnít really thought about lighting in regards to IFR as much as night. During daylight any of the colors would be fine and during daytime IFR I suspect the same would hold true.
Now at night, if using these type of switches I would definitely have them on a dimmer. Especially if you want green, blue, or white. While preserving night vision may not be critical, you still donít need a bright set of lights shining in your eyes. Yellow was definitely the most docile of the colors and if all else fails I think that would be my fallback color. Good this is the LED lights that change out so easily are about $1 each. So easy to change the color if you change your mind.
Jon
RV-14A Sold
