Dynon Servo Pulley Service Bulletin
todehnal
Has anyone researched this Servo Pulley Bulletin? I don't think that it is applicable to our auto pilot system............Tom
I researched it, and spent more time doing so than was necessary because I began by looking in the wrong places. My RV-12 is an ELSA which means that my plane’s servos were purchased directly from Van’s. The plane’s Avionics Log shows that it is equipped with two Dynon SV-32 autopilot servos. The Dynon Service Bulletin lists SV-32 servos among those that are “not” affected.
Applicability and Affected Equipment
This bulletin affects the pulley on the Dynon linear actuator, which may be found on:
Some Dynon Avionics SV42T Autopilot Servos (P/N 101008-003 / 101058-003)
Some SV32 and SV42 servos retrofitted with the Dynon linear actuator
Fig 1: Dynon SV42T servo with linear actuator
Unaffected Equipment
The following equipment is NOT affected by this service bulletin
SV32, SV32L, SV32C
SV42, SV42L, SV42EL, SV42C
SV52, SV52L, SV52C
Additionally, Dynon Certified installations are unaffected by this service bulletin.
The SB here from Dynon https://dynonavionics.com/bulletins/support_bulletin_080219.php
How determine whether the servos on an RV-12 SLSA
Anyone know how to determine whether these are the servos in the RV-12 SLSA?
