Old 07-30-2019, 05:02 PM
rjtjrt rjtjrt is offline
Default CAN Bus Can Be Hacked
Report CAN Bus is insecure to hacking.
https://www.stuff.co.nz/travel/trave...r-small-planes
Old 07-30-2019, 05:10 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
But DHS specifically states they must have "unsupervised physical access to the airplane". Not sure about you, but I know if anybody else is in my airplane wih me.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2019 Dues Paid
www.PuertoRicoFlyer.com
Old 07-30-2019, 05:11 PM
jacoby jacoby is offline
First rule of security: if someone has physical access, all other rules are void.
IMHO, this really isn't much different than someone going in and futzing with your analog gauge calibration or disconnecting an antenna or loosening a control, etc.
Now if this could be exploited without touching the CAN bus wiring, that would be a whole new world of problems.
Old 07-30-2019, 05:43 PM
dreed dreed is offline
I work in an industry that is heavily involved with the transportation industry (lots of big trucks/Mil/etc.)
All of the major truck manufactures are moving to a read only data bus/Can bus for ancillary devices for the same reasons and concerns.
https://www.trucks.com/2016/08/11/tr...yber-security/
Dan Reed
Camas, WA
RV-7A - Slider in progress - N167DR (reserved)
Working on finish kit/cowl
2018 and 2019 VAF dues paid
Old 07-30-2019, 05:56 PM
BrianDC's Avatar
BrianDC BrianDC is offline
This is not news, just someone applying what has been done in the Auto world to aviation. Wired did a piece on what someone could do if they had access to the CAN bus in Autos back in 2015 (Hint, this still required physical access in the first place):
https://www.wired.com/2015/07/hacker...-jeep-highway/
As others and even DHS have said, physical access is required. Do you realize that hackers could even hack your laptop if they got physical access to it? Seriously, this is a just silly.
It would be much easier for someone to attack the ADSB system, jam GPS, mess with the ILS or any of a number of other things.
Brian Lester
RV10 - #41778
Empennage - Done (for now)
Wings - Done (for now)
Fuselage - in progress
Finish Kit - on order
RV10builder.com
KVKX / KHEF
Old 07-30-2019, 06:35 PM
Lemmingman's Avatar
Lemmingman Lemmingman is offline
The risk, as far as I can tell is pretty low for this particular use case. Brian is right, this has been done before but is probably a good notice for us in the experimental GA world to understand that the risk, though small, does exist.
Someone doesn't have to be doing something nefarious for this to manifest itself. The basic idea is that communication on the bus is not validated in any way that it originates from a trusted source.
Fly IFR with components meant for that task. Fly VFR with eyes outside.
Gil Brice
McKinney, TX EAA-1246
RV7 - Working on fuse, fuel, brakes etc...
Old 07-30-2019, 07:06 PM
Brantel's Avatar
Brantel Brantel is offline
Same could be said of basically all the systems in GA aircraft.
Brantel (Brian Chesteen),
Check out my RV-10 builder's BLOG
RV-10, #41942, N?????, Working on Emp/Tail Cone
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Thermos's Avatar
Thermos Thermos is offline
In career #1 I was one of those people who sat around hypothesizing how a bad actor would get into safety-critical aerospace systems. It's a good way to drive yourself nuts.
I'll sleep tight tonight knowing that I'm just one person among millions using CAN bus, and if somebody really wants to mess with me there are far more time- and cost-effective ways than hacking my airplane's avionics.
ds
Dave Setser
RV-7 skin, bones, muscle, heart and nervous system complete...down to the last 1 percent
Nashua, NH (KASH)
Putting the "slow" in slow-build since 2004!
Old 07-30-2019, 11:30 PM
DaleB's Avatar
DaleB DaleB is offline
Wow. Good thing we donít use anything even less secure. You know, like USB or even RS232 serial.
Now I need an ibuprofen. My eyes rolled so hard it made my head hurt.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 07-31-2019, 01:26 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default physical security
Everyone is right - once you give physical access, all bets are off. But still, there are lots of ways that the CAN bus can and should be improved. Reminds me of the early days of ethernet and brokenring - plug something into the network and you could do anything.
Lots of scenarios I can think of that can be exploited with bad CAN security - rogue actor plugging something into the bus during maintenance, innocent actor plugging nefarious device in, etc.
Mickey Coggins
http://rv8.ch
"Hello, world!"
