I am going to have my prop dynamically balanced soon. I want to also double check my rpm accuracy at that time and reset the maximum rpm on the CS prop. The engine is a IO540-A1D5 with the crankshaft weights moved to the C4B5 configuration. Lycoming lists 2575 as the rated RPM but others tell me that?s for the HP rating in the specific application for the original engine and that 2700 is the correct max RPM. Various configurations of the IO540 use 2400 to 2800 as the rated max. Where should this engine be set? I am also curious about the rated HP. The A1D5 appears to be rated at 290Hp and the C4B5 at 250. Both at 2575 RPM.
George
George
