Old 06-25-2019, 03:35 PM
RVdreamin RVdreamin is offline
Default Antenna placement
I am getting ready to start my electrical. I would first like to mount the antennas. On the top rear skin, I am planning to install the ELT antenna near the center bulkhead. I was going to mount GPS antenna on the top skin just aft of the baggage area near the bulkhead. I would like to mount the VHF radio antenna on the bottom skin underneath the baggage area and the transponder antenna underneath the seat near the spar. Anyone see any issues. I would like to have 2 VHF radio antennas, but not sure where to put an additional antenna.
Jimmy Black
RV-9A
Started Finished 10/16/14
Wings Finished 4/9/16
Fuselage working electrical
Finishing Kit received 9/11/19
HWY
VAF paid 2019
Old 06-25-2019, 04:17 PM
dejavu dejavu is offline
Default VHF radio antennas under each seat
On the -14, Vans has two VHF radio antenna cut-outs, one under each seat. Maybe you can do the same and swap the the locations with the transponder antenna. Just a thought..
-Tom
Mooney M20-F TN
RV-14A QB
Finishing Kit
Engine + Prop. ordered
Old 06-26-2019, 08:22 AM
dwranda dwranda is offline
I am basically copying what Bruce did on his 9A.
https://www.overthehills.com/RV-9A-P...dios/i-2DSbqkW
He has a great build site!!
9A in progress
Working on Finish kit!!
Mattituck TMXIO-360 red gold
Dues paid Jan 2020
Old 06-26-2019, 09:29 AM
snoop9erdog snoop9erdog is offline
What is the best place to purchase these antennas? I also follow Bruce's site. It's excellent. Thx Bruce for the thorough documentation of your 9 build!
Ed Avila
St. Johns, AZ (SJN)
N646A RV9
Worlds longest RV build...but getting there
Old 06-26-2019, 12:49 PM
GeoffP GeoffP is offline
Default Deltapop Aviation
Try Don at Deltapop Aviation. He sells com & xpndr antennas.
RV-9, Tail Feathers done, Wings started
Old 06-26-2019, 03:10 PM
Thx Geoff....exactly what I was looking for
Ed Avila
St. Johns, AZ (SJN)
N646A RV9
Old 06-26-2019, 03:27 PM
Thanks....you Gus are the best.
Jimmy Black
RV-9A
HWY
VAF paid 2019
Old 06-26-2019, 03:34 PM
Hartstoc's Avatar
Hartstoc Hartstoc is offline
I just went through the decision process for a second VHF antenna for my new Garmin GTR20 Com2. Having seen a few examples of off field landings that put the belly on the ground and completely disabled communications because the VHF antennas were on the belly, I thought it would be a good idea to put the second one on top. This might also help with transmit range and reception when attempting to obtain clearances when on the ground at more remote airports.
The only problem is that standard whip antennas intended for top-mounting look BUTT-UGLY no matter where you locate them on top of an RV because the angle conflicts with the RV’s elegant lines. By chance, I mocked up a BENT-WHIP antenna intended for mounting underneath and, lo and behold, it looked GREAT mounted just behind the bulkhead about midway between the luggage compartment and vertical stabilizer.
I bought two beautiful identical bent-tip “red-tip” antennas from Don at DeltaPop aviation, and will mount one on the top and use the other to replace the heavier and less beautiful one already installed on the belly of my 7A. Don told me that he knows of a number of top-mounted bent whips that work great, and his are lightweight and elegantly tapered from base to tip.There may be momentary intereference with my Waas GPS antenna mounted nearby, but only briefly when transmitting if at all. I’ll be using my GTN750 Com 1 for nearly all in-flight communications in any event, and that will be transmitting through the belly-mount antenna. I’m very happy with this solution.- Otis
Otis Holt-
RV-7A (bought)
Built Monnett Moni
Frmr Test Pilot/Author CAFE APR's:
RV-8A, S-7C, Europa, Glastar.
-2019 VAF donation!!-
"RV-Fun is inversely proportional to RV-Weight!"
Old 06-26-2019, 06:25 PM
philrisl philrisl is offline
+1 for Delta Pop antennas. About half the price a s certified and work as good or better. Have used them on three airplanes. Also, Don gives excellent service.
Old 07-14-2019, 10:15 PM
scrockard scrockard is offline
This is a couple of weeks old thread..
I followed a nice pdf design from Stein.
I used two of the bottom mounted Red Tail™ Delta Pop Aviation antennas for VHF and they seem fine so far - no problems.
RV-9A - Oregon City, OR
flying since June 30,2018
2020 Dues paid
